Hi. I have one CCR1016-12S-1S+ as the primary device and a second CCR1016-12S-1S+ as backup.
The primary CCR is also a OVPN server. I want to configure the second CCR to run the backup OVPN server but so that user can authenticate with the self signed certificates I generated on the primary CCR.
I copied all the config from CCR 1 to CCR 2, exported the CA with a passphrase from CCR1 and imported to CCR2. Exported user and server certificates with passphrase and imported them.
The CA shows up as KLAT server and user certs as KAT.
When I try to connect to CCR2, OVPN show an error:
Fri Dec 21 12:01:07 2018 SIGUSR1[soft,tls-error] received, process restarting
Fri Dec 21 12:01:12 2018 TCP/UDP: Preserving recently used remote address: [AF_INET]10.0.1.254:1194
Fri Dec 21 12:01:12 2018 Attempting to establish TCP connection with [AF_INET]10.0.1.254:1194 [nonblock]
Fri Dec 21 12:01:13 2018 TCP connection established with [AF_INET]10.0.1.254:1194
Fri Dec 21 12:01:13 2018 TCP_CLIENT link local: (not bound)
Fri Dec 21 12:01:13 2018 TCP_CLIENT link remote: [AF_INET]10.0.1.254:1194
Fri Dec 21 12:01:14 2018 OpenSSL: error:14094418:SSL routines:[b]ssl3_read_bytes:tlsv1 alert unknown ca[/b]
Fri Dec 21 12:01:14 2018 OpenSSL: error:140940E5:SSL routines:[b]ssl3_read_bytes:ssl handshake failure[/b]
Fri Dec 21 12:01:14 2018 TLS_ERROR: BIO read tls_read_plaintext error
Fri Dec 21 12:01:14 2018 TLS Error: TLS object -> incoming plaintext read error
Fri Dec 21 12:01:14 2018 TLS Error: TLS handshake failed
Fri Dec 21 12:01:14 2018 Fatal TLS error (check_tls_errors_co), restarting
Fri Dec 21 12:01:14 2018 SIGUSR1[soft,tls-error] received, process restarting
Any ideas? Thank you in advance!
