Hello
i have installed the hotspot and everything works great but when i want to send emails with outlook it’s not working is it a problem of configuration or i should open some ports in MikroTik ???
thanks a lot.
Hello
thanks a lot.
Is your outlook using the default ports or any special ports?
What kind of mail account do you use? Is it POP3/IMAP4+SMTP, or Exchange, or Exchange with RPC over HTTP, or anything else?
Really i don’t know but is there any solution ??
can ip bindings slove the problem ??
