Have a pppoe link and a WAN both go through mikrotik
I did a routing mark so some users can use gateway1: pppoe link and others gateway2: WAN.
It’s all works, but receive this on WAN gateway out.
video streaming.
" File reported.
If you having this message all the time, some third party applications might be blocking the video. Try this browser
it is not happening on router WAN itself.
mangle: routing mark=route1 for pppoe, route2 for WAN
ip route 0.0.0.0/0 gateway pppoe link routing mark:route1
ip route 0.0.0.0/0 gateway WAN link routing mark:route2
I think the issue is you are not marking inbound traffic, just outbound so there is a possibility traffic is coming in through one WAN and then back out another hence getting this error.
Yes. I think you need to mark your inbound packets so that return traffic goes up the right interface.
Similar to the below, I’ve tried to copy your routing mark to make it more relevant to you. You’ll need to add these as well as your other rules, I’d put these above your other rules.
Looks like it should work as long as your source nat/masquerade rules are setup correctly. Any traffic leaving each interface should return via it given leaving packets will be presented with the IP of the egress interface.
How are your address lists defined, are they IP ranges for instance? So LAN1 (say 192.168.100.0/24) is users1 and LAN2 (say 192.168.200.0/24) is users2?
My guess is that there is a lack of definition around this part. If this is not clear you might need to mark connections first then mark routing, this way return traffic would be mapped to the connection, then a return routing rule required with the same routing mark. That some of this is working is confusing.
Does flipping the active default route out make any difference to which interface this has this problem associated?
