Hi to every body! I need some help. If I call, they hear me, but I can’t hear they (One Way Audio)
First I Configure PPPoE, Then LAN Network (192.168.0.1/24), That Work Fine
add address=192.168.0.1/24 comment=defconf interface=ether2 network=192.168.0.0
add address=222.222.222.218/30 comment=defconf interface=ether5 network=222.222.222.216
add distance=1 dst-address=199.99.99.10 gateway=222.222.222.217 (199.99.99.10 is the ISP SIP)
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=accept chain=forward comment=“ALLOW ASTERISK CONNECTIONS/REPLIES TO OUTSIDE (INTERNET)” protocol=udp src-address=192.168.0.100
add action=accept chain=forward comment=“ALLOW FORWARDED CONNECTIONS/REPLIES TO INSIDE (LAN)” dst-address=192.168.0.100 dst-port=5060,10000-20000 protocol=udp
add action=accept chain=forward connection-nat-state=dstnat in-interface=ether5
add action=accept chain=forward comment=SIP in-interface=ether5
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
add action=masquerade chain=srcnat comment=“WAN SIP” ipsec-policy=out,none log=yes out-interface=ether5
add action=dst-nat chain=dstnat comment=“NAT SIP” in-interface=ether5 log=yes to-addresses=192.168.0.100
add action=dst-nat chain=dstnat in-interface=ether5 protocol=udp to-addresses=192.168.0.100
add action=dst-nat chain=dstnat dst-port=5060 in-interface=ether5 protocol=udp to-addresses=192.168.0.100 to-ports=5060
add action=dst-nat chain=dstnat dst-port=5061 in-interface=ether5 protocol=udp to-addresses=192.168.0.100 to-ports=5061
add action=dst-nat chain=dstnat dst-port=10000-20000 in-interface=ether5 protocol=udp to-addresses=192.168.0.100 to-ports=10000-20000
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes sip-direct-media=no
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
If I do a Ping to 199.99.99.10 it’s ok
1 199.99.99.10 56 62 3ms
