MIKRO TIK CCR2216-1G-12XS-2XQ Router and using an Ubiquity Pro XG 10 PoE Switch.
Would very much appreciate advice about selecting Transceivers,
The ubiquiti switch needs a controller for configuration.
Otherwise should work.
The fastest they can do between them is 10G since the Pro XG 10 PoE has SFP+ ports and the SFP28 ports on the CCR2216 run fine at 10G. So grab a pair of 10G SFP+ modules of the same type and wavelength plus fiber. Any MikroTik 10G SFP+ is fine on the CCR side. I'm not sure what works best in the Pro XG though. Ubiquiti doesn't normaly block third party modules but only guarantees their own so a Ubiquiti module in the switch is the safe bet.
In the same rack a 10G SFP+ DAC is cheaper and will most likely work too but mixing vendors is a bit more hit and miss than with optics.
The UniFi controller can run on the CCR2216 itself as a container since it's arm64 with 16 GB RAM. You'll need to add an M.2 SATA SSD since the internal NAND is only 128 MB and also install the container package in ROS. There's a ready made arm64 image, pospa/ccr2116-unifi, that's based on jacobalberty/unifi-docker and tested on CCR.
Btw, once the Pro XG is configured you don’t actually need the controller. But if you still want stats, alerts, firmware updates or to make config changes you’ll need it running. Since the CCR2216 is always on anyway that works out nicely.
