Mikro2.9.2
Hi
problem with my mt… I set all up and it works, it worlks like a humble AP for little wifi community, but when the comp (where MT is installed) powers off, and then on I cant ping eth neither the wlan interface why???
Router switched off ?
one more time, are you saying that when you switch off the MT Router, you can’t ping it any more?
@sergejs,normis
Hi
problem with my mt… I set all up and it works, it worlks like a humble AP for little wifi community, but when the comp (where MT is installed) powers off, and > then on > I cant ping eth neither the wlan interface why???
Do you have monitor on this router? It sounds like problem with PC, i mean it doesn’t start normal after “hard reboot”. How do to “powers off, and then on”? Did you make hardware or software changes … and etc?
P.S. I mean you gave very little info for help …
:smiley:
yes, please tell us more info. what does the router show on screen after powering up? why did it turn off, did you turn it off, or it turned off by itself? can you make a supout.rif file after it is powered on, and send that file to support?
Okay sorry my vocabulary is modest, well i ran out of electric power :slight_smile: and when it came back I couldn ping my lan card. But I solved the problem. My Hard Disk died :slight_smile:, stupid problem but…
reason I put hard and not flash is because I dont have money for flash and hard disk was conner peripherals 80Mb :slight_smile: about 15 years old :slight_smile: hi hi
