dev tap
remote X.X.X.X 1194
proto tcp-client
tls-client
ca C:\Program Files\OpenVPN\config\ca.crt
cert C:\Program Files\OpenVPN\config\clinet.crt
key C:\Program Files\OpenVPN\config\clinet.key
auth-user-pass
pull
nobind
persist-key
resolv-retry infinite
verb 3
script-security 2 system
route-up “route add LAN-IP mask 255.255.255.0 172.21.0.1?
auth-nocache
This is My clinet config file And on the server i build cerficate by openvpn on centos and import on mikorik server my ip X.X.X.X
And Copy ca.crt clinet.crt clinet.key
on folder config openvpn GUI on windows 7
but when i press Connect
say Connection failed
what is problem?
