I purchased a mikronoc 2200 ,I did an upgrade to my router from version 4.11 to 5.2 OS, then i already had a router board 750 with configured vpn clients and other things, a person did a backup from the 750 configuration and did an upload with that same image to the 22000 and know i cant connect to my 2200 , can i make a factory restart to the 2200 ?? and is there a way to connect to the router that’s not by winbox and whats the right cable to connect to console port or what other method can i use.
You can use netinstall over a serial cable to get back into the device.
