What version can i upgrade because when i go to mikrotik page i dont see model number 2200
The MikroNoc 2200 is not a MirkoTik product. It is a Axiomtek NA-820 x86 machine which is re-sold under different brand names (MikroNoc, PowerRouter, etc) by various companies with RouterOS pre-installed. Refer to this post for more info.
The correct packages you want to download are the x86 packages.
Thank you , that was helpful , and do you know the right cable and parameters to connect to the 2200 or 735 via console and what are the usb ports for??
