I am trying to make a nodejs script base on mikronde . I tried to run the examples but i have a lot of issues.
E.g:
If I run this code
var api = require('mikronode');
var connection = new api('192.168.0.1','admin','password');
connection.connect(function(conn) {
conn.closeOnDone(true); // All channels need to complete before the connection will close.
var listenChannel=conn.openChannel();
listenChannel.write('/interface/listen',function(chan) {
chan.on('read',function(data) {
packet=api.parseItems([data])[0];
console.log('Interface change: '+JSON.stringify(packet));
var actionChannel=conn.openChannel();
// These will run synchronsously
actionChannel.write(['/interface/set','=disabled=yes','=.id=ether1']); // don't care to do anything after it's done.
actionChannel.write(['/interface/set','=disabled=no','=.id=ether1']); // don't care to do anything after it's done.
actionChannel.write('/interface/getall',function(chan) {
chan.on('done',function(data) {
packets=api.parseItems(data);
packets.forEach(function(packet) {
console.log('Interface: '+JSON.stringify(packet));
listenChannel.close(); // This should call the /cancel command to stop the listen.
actionChannel.close(); // The above commands will complete before this is closed.
.. i obtain this error :
RangeError: "msecs" argument must be a non-negative finite number
at Object.exports.enroll (timers.js:302:11)
at Socket.setTimeout (net.js:327:12)
at SocketStream.setTimeout (D:\work\node\test-api\node_modules\mikronode\dist\mikronode.js:505:32)
at new SocketStream (D:\work\node\test-api\node_modules\mikronode\dist\mikronode.js:472:15)
at MikroNode.connect (D:\work\node\test-api\node_modules\mikronode\dist\mikronode.js:296:30)
at D:\work\node\test-api\index.js:10:13
at Layer.handle [as handle_request] (D:\work\node\test-api\node_modules\express\lib\router\layer.js:95:5)
at next (D:\work\node\test-api\node_modules\express\lib\router\route.js:131:13)
at Route.dispatch (D:\work\node\test-api\node_modules\express\lib\router\route.js:112:3)
… I figure out this is happen only when the connection object don’t have a then function like in the next example…
E.g 2:
var MikroNode = require('mikronode');
var device = new MikroNode('192.168.0.1');
device.connect('admin','password').then(function(conn) {
listenChannel.write('/interface/listen');
// Each sentence that comes down goes through this.
listenChannel.read.subscribe(function(data) {
var packet=MikroNode.resultsToObj(data);
actionChannel.sync(true);
actionChannel.write('/interface/set',{'disabled':'yes','.id':'ether1'});
actionChannel.write('/interface/set',{'disabled':'no','.id':'ether1'});
actionChannel.write('/interface/getall');
actionChannel.on('done',function(packet) {
packet.data.forEach(function(data) {
var packets=MikroNode.resultsToObj(data);
In this code i put console.log() message and the function done is never executed. I observe after chan.write() function the console.log() message is never displayed.
I spent today more then 5 hours trying a lot of combination but without any success.
Thank in advice.
Bogdan
