mikrotic 4.17 dont send to freeradius
hi guy
i have set a pppoe server with mikrotik 4.17 the pppoe work great.
but now when i try to add a radius server. i have some config issues.
mikrotic can ping freeradius server
freeradius can ping mikrotic to.
i know i have set the user correctly :
Password:test
service:pppoe
Caller ID: PPPOE
now radius config from mikrotic
Service: ppp
address:10.100.8.2 (freeradius address)
secret:(freeradius secret)
authentication port: 1812
accouning port : 1813
timeout:100ms
BUT the status of radius Stay a 0
Thanks for your help
Try with a remote user, not the local… xD
i try to connect with my user test set on mikrotic ..
If you set the user in the mikrotik… why you need a radius?
routeros first search the user in local database. Later in remote (the radius server).. then… if the user is in local.. the radius don’t do nothing.
hoooo THANKS ! I will try
