Mikrotik 1100AH in switching mode
Hi all,
can we use Mikrotik 1100AH as it is L3 switch(i.e. cisco, zyxel,allied, juniper).
need to configure both Vlan trunk & access port in Mikrotik 1100 AH . port 1 to 8 will be the access port with different VLAN and port 10 will be trunk port ..
Regards,
Mak
This configuration is not possible as ether1-ether5 and ether6-ether10 belongs to separate switch chips.
However toyu cab make the following configuration for each switch group separately:
http://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features#Example_-_802.1Q_Trunking_with_Atheros_8316
