MikroTik 2.8.11 - Parent Proxy Problem
I was using MikroTIk 2.7 as a transparent proxy, with transparent proxy to point to my FreeBSD proxy. All was working well, until i upgraded to 2.8.11. Now, with the parent proxy specified in the mikrotik, it will not work. Any ideas? Is this a bug?
It must be a config problem as we have 2.8.11 working as a transparent proxy which in turn directs traffic to a central filtering proxy.
Double check the firewall rules, making sure that the proxy has access to the parent.
I just checked and there are no firewall rules preventing access. Also, it was working fine in v 2.7, but after the upgrade to 2.8.11, it no longer works. Nothing was changed between the working point, and now besides the version upgrade.
You’re going to have to do a little testing…
  1. Does the transparent proxy work without the parent set?
  2. If yes, you need to check that Mikrotik has access to the
    parent (go to 2a). If no goto step 3
2a. Double check the firewall rules (again!) Perhaps
change the input/output rules default to “accept” if your
box is on a LAN. Does it work now? If it does you need to
tweak the firewall rules.
2b. Double check that the parent proxy is still operational
2c. Perhaps re-enter the parent proxy settings.
2d. We’re not running windows, but have you tried a reboot?
  1. It seems the transparent proxy isn’t working at all. Double check
    the dst-nat rule is redirecting TCP Port 80 to the correct local port
    (default 3128).
Hope that helps a little. Its really a case of troubleshooting the issue.
The box I have 2.8.11 running on started out as 2.8.x box, so it is
possible that something nasty happens when you upgrade from 2.7.
-nathan
Thanks for you help…any other ideas you can think of? I am thinking it was a problem with the upgrade because we have nothing in place that should prevent this from working (as it did before the upgrade).
