mikrotik 2.8.16 & FreeRadius+OpenLDAP
hi,
I have a problem in the authentication hotspot using my radius server…
The system radius+ldap in PAP mode works. with the mikrotik (ke it uses CHAP) gives this problem to me:
rad_recv: Access-Request packet from host 192.168.2.253:1024, id=3, length=150
NAS-Identifier = “MikroTik”
NAS-Port-Type = Ethernet
Calling-Station-Id = “00:01:4A:5D:30:6F”
Called-Station-Id = “00:11:95:25:48:62”
NAS-Port-Id = “ether2”
User-Name = “pastore”
NAS-Port = 2148532235
Acct-Session-Id = “8010000b”
CHAP-Challenge = 0x7a06a6f8c49d9cda1d3381a3dd0d8313
CHAP-Password = 0x1d3e1a04b105dcc59905931be1eb825771
NAS-IP-Address = 192.168.2.253
rad_lowerpair: User-Name now ‘pastore’
rad_rmspace_pair: User-Name now ‘pastore’
Processing the authorize section of radiusd.conf
modcall: entering group authorize for request 20
modcall[authorize]: module “preprocess” returns ok for request 20
rlm_chap: Setting ‘Auth-Type := CHAP’
modcall[authorize]: module “chap” returns ok for request 20
rlm_ldap: - authorize
rlm_ldap: performing user authorization for pastore
radius_xlat: ‘(uid=pastore)(objectclass=radiusprofile)’
radius_xlat: ‘ou=users,ou=radius,dc=wai-fly,dc=com’
rlm_ldap: ldap_get_conn: Checking Id: 0
rlm_ldap: ldap_get_conn: Got Id: 0
rlm_ldap: performing search in ou=users,ou=radius,dc=wai-fly,dc=com, with filter (uid=pastore)(objectclass=radiusprofile)
rlm_ldap: looking for check items in directory…
rlm_ldap: looking for reply items in directory…
rlm_ldap: Adding radiusIdleTimeout as Idle-Timeout, value 600 & op=11
rlm_ldap: user pastore authorized to use remote access
rlm_ldap: ldap_release_conn: Release Id: 0
modcall[authorize]: module “ldap” returns ok for request 20
modcall: group authorize returns ok for request 20
rad_check_password: Found Auth-Type CHAP
auth: type “CHAP”
Processing the authenticate section of radiusd.conf
modcall: entering group Auth-Type for request 20
rlm_chap: login attempt by “pastore” with CHAP password
rlm_chap: Could not find clear text password for user pastore
modcall[authenticate]: module “chap” returns invalid for request 20
modcall: group Auth-Type returns invalid for request 20
auth: Failed to validate the user.
Login incorrect (rlm_chap: Clear text password not available): [pastore/] (from client Mikrotik port 2148532235 cli 00:01:4A:5D:30:6F)
Delaying request 20 for 1 seconds
Finished request 20
Going to the next request
— Walking the entire request list —
Waking up in 1 seconds…
Sending Access-Reject of id 3 to 192.168.2.253:1024
Waking up in 5 seconds…
Cleaning up request 20 ID 3 with timestamp 4329ab85
Nothing to do. Sleeping until we see a request.
you know as I can resolve the problem or like sending the password in PAP (text clear)?
When using CHAP with RADIUS, you have to have your users’ passwords in CLEAR TEXT in your database (or users file) - this is also stated somewhere in the error message your posted.
That’s enforced by design, and not a failure of MikroTik or FreeRadius…
hi,
the problem and that in database(LDAP) the password memorizzate a clear text :frowning: but it continues not to work…
dn: uid=pastore,ou=users,ou=radius,dc=wai-fly,dc=com
sn: Petulla
telephoneNumber: xxxxxxxxxxx
radiusIdleTimeout: 600
mail: xxxxxxx@hotmail.com
objectClass: inetOrgPerson
objectClass: radiusprofile
uid: pastore
cn: Emanuele
radiusGroupName: wireless
userPassword: pastore
you have other suggestion in order to resolve this annoying problem?
no help?
no help?
