does any one uses mikrotik routers after a windows based computer having windows 2003 server and isa server 2004 installed on it and having a download link via satellite and working fine with him cause i have a problem and would like any suggestions or help. pls if any one tell me to post my problem thanks
yes I do !!! and it works fine
but please post here your configuration and i will check where is the problem with your configuration
regards,
I want to have isa server 2004 for cashing and please tell my haw to conigure to work mikrotik and isa 2004
i dont know why you should combine ISA and MT one of them can do it, on LAN i had ISA servers and i have completly removed them from my network and now im doing fine with MT.
I have 8 Branch offices which are being connected to the Main office using VPN connects i had a hadache and every day problems doing this with ISA and WIN2k Server and With MT i dont remember last time i had he smalledt problem on VPN Connections.
Well my use for isa server isa cause i have a downlink via sattelite (a vpn connection) if u know napairnetworks a way to do it without a microsoft windows pc pls tell me.
ok now to marron thanks for volunteering to help
here is my scenario.
i have a dedicated connection say ip address: 195.112.155.113
subnet mask: 255.255.255.240
default gateway: 195.112.163.144
primary dns: 195.112.195.135
secondaty dns: 195.112.198.171
my download connection has a dns: 66.157.193.238
and a proxy :66.157.193.4 port :80
ok
i finished the configuration of iza and i made the routing and remote address for the vpn connection and i made the configuration for the second network card to be 20.20.20.1
now for the mikrotik
the internet network card ip address is 20.20.20.2
i put the dns of the dedicated connection the 195.xx.xx.xx
should i use the one of the vpn connection or it is correct to use only of the dedicated connection
also in the webproxy i use a transparent proxy of 20.20.20.1 port 8080
is there a place i should enter the proxy of the vpn or that is correct.
well if u need i can do a print scren for my configuration to be more precise.
the problem in this configuration is that i have a problem if i am uploading attachments in hotmail or yahoo.
msn is taking a lot of time to log in and secure websites such as creating new account on hotmail sometimes work and sometimes not. thanks for any help from any body
hello there, no one to help, hi maroon do u want anyother details to help me or what???
