Mikrotik 2 Wan 1 LAN load balancer with fail over problem
Hi all,
I’m the mikrotik newbies.
I try to do the dual wan load balancer with fail over (by checking ping the internet status for WAN1 and WAN2 (I mean ISP1 and ISP2) using below command.
#| Define all parameters
:global wanAddress1 192.168.5.2/29
:global wanNetwork1 192.168.5.0
:global wanNetwork1Subnet 192.168.5.1/29
:global wanBroadcast1 192.168.5.7
:global wanGateway1 192.168.5.1
:global wanAddress2 192.168.5.10/29
:global wanNetwork2 192.168.5.8
:global wanNetwork2Subnet 192.168.5.9/29
:global wanBroadcast2 192.168.5.15
:global wanGateway2 192.168.5.9
:global localAddress 192.168.88.1/24
:global localNetwork 192.168.88.0
:global localNetwork2 192.168.88.0/24
:global localBroadcast 192.168.88.255
:global localGateway 192.168.88.1
:global localDNS 192.168.88.1
:global localPool 192.168.88.10-192.168.88.253
:global dnsServer 8.8.8.8,8.8.4.4
#| Assign interace’s name
/interface set “ether1” name=“PORT1_WAN”
/interface set “ether2” name=“PORT2_WAN”
/interface set “ether3” name=“PORT3_LAN”
/interface set “ether4” name=“PORT4_LAN”
/interface set “ether5” name=“PORT5_LAN”
#| Assign master port switch
/interface ethernet set PORT4_LAN,PORT5_LAN master-port=PORT3_LAN
#| Assign ipaddress to our interfaces
#| Port 1 → WAN 1
/ip address add address=$wanAddress1 network=$wanNetwork1 broadcast=$wanBroadcast1 interface=PORT1_WAN
#| Port 2 → WAN 2
/ip address add address=$wanAddress2 network=$wanNetwork2 broadcast=$wanBroadcast2 interface=PORT2_WAN
#| Port 3 → Local LAN
#| Port 4 → Local LAN
#| Port 5 → Local LAN
/ip address add address=$localAddress network=$localNetwork broadcast=$localBroadcast interface=PORT3_LAN
#| 1,2
#| Mark incoming package on input’s chain
/ip firewall mangle add chain=input in-interface=PORT1_WAN action=mark-connection new-connection-mark=PORT1_WAN_conn
/ip firewall mangle add chain=input in-interface=PORT2_WAN action=mark-connection new-connection-mark=PORT2_WAN_conn
#| 3,4
#| Mark routing package on output’s chain
/ip firewall mangle add chain=output connection-mark=PORT1_WAN_conn action=mark-routing new-routing-mark=to_PORT1_WAN
/ip firewall mangle add chain=output connection-mark=PORT2_WAN_conn action=mark-routing new-routing-mark=to_PORT2_WAN
#| 5,6
#| Accept all packages if they come from local
/ip firewall mangle add chain=prerouting dst-address=$wanNetwork1Subnet action=accept in-interface=PORT3_LAN
/ip firewall mangle add chain=prerouting dst-address=$wanNetwork2Subnet action=accept in-interface=PORT3_LAN
#| 7,8
#| Do the load balance package
/ip firewall mangle add chain=prerouting dst-address-type=!local in-interface=PORT3_LAN per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=PORT1_WAN_conn passthrough=yes
/ip firewall mangle add chain=prerouting dst-address-type=!local in-interface=PORT3_LAN per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=PORT2_WAN_conn passthrough=yes
#| 9,10
#| Mark output network for packages
/ip firewall mangle add chain=prerouting connection-mark=PORT1_WAN_conn in-interface=PORT3_LAN action=mark-routing new-routing-mark=to_PORT1_WAN
/ip firewall mangle add chain=prerouting connection-mark=PORT2_WAN_conn in-interface=PORT3_LAN action=mark-routing new-routing-mark=to_PORT2_WAN
#| Add routing table
/ip route add dst-address=8.8.8.8 gateway=$wanGateway1 scope=10
/ip route add dst-address=203.144.207.29 gateway=$wanGateway1 scope=10
/ip route add dst-address=8.8.4.4 gateway=$wanGateway2 scope=10
/ip route add dst-address=203.144.207.49 gateway=$wanGateway2 scope=10
/ip route add dst-address=10.1.1.1 gateway=8.8.8.8 scope=10 target-scope=10 check-gateway=ping
/ip route add dst-address=10.1.1.1 gateway=203.144.207.29 scope=10 target-scope=10 check-gateway=ping
/ip route add dst-address=10.2.2.2 gateway=8.8.4.4 scope=10 target-scope=10 check-gateway=ping
/ip route add dst-address=10.2.2.2 gateway=203.144.207.49 scope=10 target-scope=10 check-gateway=ping
/ip route add distance=1 gateway=10.1.1.1 routing-mark=to_PORT1_WAN
/ip route add distance=2 gateway=10.2.2.2 routing-mark=to_PORT1_WAN
/ip route add distance=1 gateway=10.2.2.2 routing-mark=to_PORT2_WAN
/ip route add distance=2 gateway=10.1.1.1 routing-mark=to_PORT2_WAN
#| Assign NAT
/ip firewall nat add chain=srcnat out-interface=PORT1_WAN action=masquerade
/ip firewall nat add chain=srcnat out-interface=PORT2_WAN action=masquerade
#| Assign allow DNS
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=$dnsServer
#| Assign DHCP server
/ip pool add name=default-dhcp ranges=$localPool
/ip dhcp-server add name=default address-pool=default-dhcp interface=PORT3_LAN disabled=no
/ip dhcp-server network add address=$localNetwork2 gateway=$localGateway dns-server=$localDNS
Even though the load balance work very well.I found that when I try to ping to some destination let say “www.facebook.com” and saw that this ping packet pass through my “Wan1” port and then I try to make my “Wan1” internet down but WAN1 port still up.
I found that my ping to “facebook.com” lost without any fail over to my WAN2 which is working.
I also try to make another ping session with the same destination (facebook.com) but ping cannot reach the destination I meant the ping packet to facebook.com will pass through only my WAN1 port without going to WAN2.Does anyone know what wrong with my load balance command?
Ps.when I make WAN1 internet down if it’s not facebook.com which was pinging before WAN1 down others website can ping through WAN2 automatically.
Thank you very much
Try this one.
In dutch but see to the code this is a working script
You must change the IP-adresses (red and green colored) to this from you ISP
http://www.wirelessinfo.be/index.php/mikrotik/pages/load-balance
