I just successfully made my first Point-to-Point Setup with 2 Mikrotik SXT-Lite2 Devices.
The Distance is only around 250m which are Bridged. Signal Strength is arount -40db.
The AP is configured as Bridge, and the Station as Station-Bridge, and with the Bandwidth Test from the Mikrotik Panel I only get around 20-25Mbps.
The Devices are configured to B/G/N Speed.
What could I do to increase Bandwidth Speed, which Protocol would be best to use.
The Setup has been made in a small Village, so there are not so many Ap’s in the 2ghz frequency.
As far as I understand, the SXT-Lite2 is a N-capable Device, with Speeds up to 150Mbps,
so my first Guess was that I should be able to gain around 100 - 120Mbps out of the PTP Tunnel.
Any help or Advice appreciated.
