Greetings all
when i install mikrotik os Spftware on my pc
i choose PPP
when it installed i open via ssh or winbox
no PPP Features?
is there any PPP( PPPoe) Feature in Mikrotik 3.20
thx
To check you have PPP package installed, select System, packages. If PPP listed, then yes, you have PPP features. You must then create the type of PPP settings that are required.
