Hi all,
can i use mikrotik 3.30 on a powerouter 732 or it have some problem ?
On powerouter website, they suggest to use 3.24 no new version.
Hi all,
I think they are slow to update the website. It is just an x86 PC. There is no reason why 3.30 and 4.2 should not work.
Tom
On the site i read:
Current 3.24 is recommended for the PowerRouter 732
DO NOT UPGRADE ABOVE 3.25!
You could loose all IP connectivity. Mikrotik has confirmed this to be an issue.
On the router i’ve more then 70mbps of traffic, and it was at 100km from my office…i must be safe about upgrading to 3.30.
We need the new firewall matcher…
in this case, you should ask them about it
I put this issue to linktechs.net and they replied:
“Make sure you have /system hardware multi-cpu set to yes, if not, you will lose all Ethernet ports. Otherwise, you can upgrade to v4.11 if you wish”
this worked for me!
