Mikrotik 3.x log question ...
Does anybody know how to enable Log on Mktk 3.7 ?
Actually, I’m trying to configure IPsec but log is empty all the time … I really don’t know how to properly debug or troubleshoot P1 and P2 phases ?
Thank you,
D.
Go to SYSTEM → LOGGING
click on the plus sign and on the topic select IPSEC make sure the action is set to MEMORY.
I hope this helps.
-sincerely,
DesertAdmin
Thank you for the answer,
it works !
However, I have one more question - why I am not able to choose exchange mode to ‘aggresive’ ?
When I try to do taht I get the error message :
Couldn’t change IPsec peer <x.x.x.x> - Unsafe configuration. Suggestion to use certificates
In ver 2.9 I was able to change the mode without any problems.
How to overcome this problem ?
Thank you,
D.
Hmm that I am not sure of. Hopefully some one else could chime in on this subject.
-Sincerely,
DesertAdmin
