Mikrotik /31 Subnet - RFC3021
Hi ,
I´m trying to do some tests with subnet /31. I found in the forum that there is a workaround to use the /31 subnet in PTP ethernet links.
Does anyone know if Mikrotik suport the RFC3021 in the last Ros?
If no, is there a roadmap to Mikrotik enable/suport this feature?
Thanks in advanced,
Regards
From what I see Mikrotik is expanding to carrier grade routers with CCR line.
As has support to RFC3021 is commonly used by carriers does Mikrotik has this feature on roadmap?
Thanks,
David
Use /32 instead.
thumbs up
