Hello, has anyone used the above pair successfully?
i got one unlocked unit off ebay. Have been trying to get it to run but i’m encountering some issues.
[admin@MikroTik] /interface ppp-client> info 0
status: “ready”
pin-status: “no password required”
functionality: “minimum”
gprs-class: “A - GPRS & GSM simultaneous”
manufacturer: “Sierra Wireless, Inc.”
model: “MC8780”
revision: “F1_2_3_15AP C:/WS/FW/F1_2_3_15AP/MSM7200R3/SRC/AMSS 2008/07/09 13:02:11”
serial-number: “356686010653687”
current-operator: “”
access-technology: “”
signal-strengh: 0
frame-error-rate: “unknown”
it doesn’t seem to show any signal strength.
performing scan 0 will just show ERROR.
[admin@MikroTik] /interface ppp-client> /system resource usb print
DEVICE VENDOR NAME SPEED
0 2:1 RB400 EHCI 480 Mbps
1 1:1 RB400 OHCI 12 Mbps
2 1:3 Sierra Wireless, Incorporated AirCard 12 Mbps
[admin@MikroTik] /interface ppp-client> /port print
Flags: I - inactive
NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console auto
1 usb2 3 9600
2 I usb3 3 9600
[admin@MikroTik] /interface ppp-client> /system serial-terminal usb2 channel=2
[Ctrl-A is the prefix key]
ATI
Manufacturer: Sierra Wireless, Inc.
Model: MC8780
Revision: F1_2_3_15AP C:/WS/FW/F1_2_3_15AP/MSM7200R3/SRC/AMSS 2008/07/09 13:02:11
IMEI: 356686010653687
IMEI SV: 13
FSN: D330348475010
3GPP Release 6
+GCAP: +CGSM,+FCLASS,+DS
OK
[admin@MikroTik] /interface ppp-client> enable 0
(30 messages discarded)
echo: async,ppp,debug,packet ppp-out1: rcvd CHAP Success id=0x1
echo: async,ppp,debug ppp-out1: IPCP lowerup
echo: async,ppp,debug,packet ppp-out1: sent IPCP ConfReq id=0x10
echo: async,ppp,debug,packet <addr 0.0.0.0>
echo: async,ppp,debug,packet <ms-dns 0.0.0.0>
echo: async,ppp,debug ppp-out1: IPCP open
echo: async,ppp,debug ppp-out1: BCP open
echo: async,ppp,debug ppp-out1: CCP lowerup
echo: async,ppp,debug ppp-out1: CCP open
echo: async,ppp,debug ppp-out2: LCP lowerdown
echo: async,ppp,debug ppp-out2: LCP down event in initial state
[admin@MikroTik] /interface ppp-client> monitor 0
status: “authenticated”
uptime: 17s
idle-time: 17s
mtu: 1500
mru: 1500
[admin@MikroTik] /interface ppp-client> print
0 name=“ppp-out1” max-mtu=1500 max-mru=1500 mrru=disabled port=usb2 data-channel=2 info-channel=2 apn=“shinternet” pin=“” user=“” password=“” profile=default phone=“*99#” dial-command=“ATDT”
modem-init=“at+cgdcont=1,“ip”,“shinternet”” null-modem=no dial-on-demand=no add-default-route=yes use-peer-dns=yes keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
So if anyone has any clue whatsoever, please help! The exact same dial string and APN works with my Huawei E1550 USB stick.
