Mikrotik 450G Disk space showing 98%
Hi Everyone,
This is aztech we are ISP at India and we are using Mikrotik 450G RouterBoard in our networks all the network is fine but, since few days we have an issue with one of our 450G Router is showing us disk utilization is 98% compare to other all RouterBoards are hardly 8-9% only.. as the issue in disk space some times users are unable to getting login page on that router after manually rebooting router its working but disk space is showing 98%.. we have tried to reset all config and reset router as well but the disk space is showing still same… Please any buddy have Idea about this issue it will be great help to us… thanks in advance waiting for replay.
aztech44
  1. Go under “files” and make sure nothing is there that shouldn’t be.
  2. Go under ip->services and make sure ftp is disabled so you don’t have anyone uploading files.
  3. Go under system->packages and uninstall any you aren’t using.
Thanks for your replay,
I have removed every thing from file and unused packages even the size is same.
Are you certain you are looking at disk and not CPU utilization?
