mikrotik 5009 not booting
I’ve got problem with Mikrotik 5009. Device is not booting, I’ve tried to reset, but no success. Port 1 blinking, but I can’t reach device from PC. From PC I can see messages - “Cable connected” and “Cable disconnected”… Can someone suggest something?
Have you tried netinstall?
https://help.mikrotik.com/docs/display/ROS/Netinstall
Its not booting or it does a boot loop ?
From OP description, probably boot loop…
Thats what i think too…
Yep, I’ve tried Netinstall, I can’t see Device after resetting, I’ve tried several times… In Windows I can see that Network Adapter shows - “Unidentified Network” and “Cable is disconnected”
Did you actually netinstall the device ?
And after that the problem persists ?
I recommend watching my video on YouTube about how Netinstall works so that you’re doing it all correctly.
https://www.youtube.com/watch?v=-mOGD1-Uv2Y
