MikroTik 6.2 Code DNS ?
MikroTik 6.2 Code Dynamic DNS ?
Get the code that works with 6.2.
I can not help it. Please. :frowning: :frowning:
I am having the same problem... after the update, my ddns script stoped to work..
can some one help please...
cheers
ON the log I always get the same meessage: No-IP: Previous IP is equal to current IP....
My Script:
No-IP automatic Dynamic DNS update
#--------------- Change Values in this section to match your setup ------------------
No-IP User account info
:local noipuser "ptkferraro"
:local noippass "tri062127"
Set the hostname or label of network to be updated.
Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
To specify multiple hosts, separate them with commas.
:local noiphost "resalameda.no-ip.biz"
Change to the name of interface that gets the dynamic IP address
:local inetinterface "eth1-Link1"
No more changes need
:global previousIP
:if ([/interface get $inetinterface value-name=running]) do={
Get the current IP on the interface
:local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address]
Strip the net mask off the IP address
:for i from=( [:len $currentIP] - 1) to=0 do={
:if ( [:pick $currentIP $i] = "/") do={
:set currentIP [:pick $currentIP 0 $i]
:if ($currentIP != $previousIP) do={
:log info "No-IP: Current IP $currentIP is not equal to previous IP, update needed"
:set previousIP $currentIP
The update URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character #in commands.
:local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP"
:local noiphostarray
:set noiphostarray [:toarray $noiphost]
:foreach host in=$noiphostarray do={
:log info "No-IP: Sending update for $host"
/tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=http dst-path=("no-ip_ddns_update-" . $host . ".txt")
:log info "No-IP: Host $host updated on No-IP with IP $currentIP"
} else={
:log info "No-IP: Previous IP $previousIP is equal to current IP, no update needed"
#} #else={
#:log info "No-IP: $inetinterface is not currently running, so therefore will not update."
Why are these lines commented out?
# :if ($currentIP != $previousIP) do={
# :log info "No-IP: Current IP $currentIP is not equal to previous IP, update needed"
# :set previousIP $currentIP
Thank you. 2fast4youbr,
your Code can use Thank you. :slight_smile: :slight_smile: :slight_smile:
Sorry for asking guys, bu twhat is this script actually doing? :confused:
Accidentally updated to 6.3 but the Auto Update.
Involuntarily.
Code 6.2 is not available in 6.3.
:blush: :blush: :blush:
