I have R210/II Dell servers, but after installing version 6rc8 they do not work the network interfaces.
I’ve tried other versions 6rc * still did not work.
The version comes 6rc8 crash the system.
please email support@mikrotik.com with remote access to where we could see this issue
Normis,
The network interface does not work. I can not give remote access.
They are not recognized at all? It could be possible that they are not supported in v6. The previous version where they worked was v5.22?
Yes, is not recognized at all. I tested it on several different servers.
Yes, they work in v5.22.
It hangs when accessing Ethernet network interface. Freezes the screen.
ok then, make a supout.rif file, downgrade to v5.22, and download the file. send it to support. we will check if we can add the correct driver support in rc9/10
same here, after load RC8 and reboot all was fine till I reboot for firmware upgrade
then whole RB433AH hanged with 100% CPU usage for wifi interfaces
LAN and wifi interfaces even not appear in interface list
fortunately I could winbox by MAC and downgrade to 5.23
got that problem also on RB 411
I’ve seen this an all 6RC releases and reported it to MT for every release
It’s not on every RB with wireless - some work.
I can’t see what is the factor that make it work on some and some not
I’ll post some more info supout to MT tomorrow
RGDS
