MikroTik 715 Wireless problem with Time Capsule
Hello everybody!
How can I use Time Capsule as another access point and make roaming network with MikroTik and it’s existing wireless network. Time Capsule makes connection with wireless network but not via ethernet cable. Should I use WAN or LAN port?
BR
Miikka
I suggest that you set up dhcp client on your timecapsule and put it in bridge mode. Use LAN port just in case.
http://i.imgur.com/X4rjfuY.png
