Mikrotik 802.11ac and Macbook/Broadcom
I’m using a RB922UAGS-5HPacD in a RF Elements StationBox for home wireless.
Unfortunally it have never performed that great with one of our computers, a late-2014 Macbook Pro model. The speed is extremly varying and crippled. From 10Mbps to 110Mbps. It often starts in the 80-90’s then drops to 10-30’s. 5Ghz interferance is quite low in the area. Free line of sight to the antennas. Signal about 45-55dB. TX-rate is 433Mbps-80Mhz/1S/SGI but drops when used.
I have a old TP-Link running OpenWRT as a bridge for TV/Stereo-stuff, and it always performs flawless against the RB922 (iperf 80-120Mbps at 11an:150Mbps-40MHz/1S/SGI) I also have a Samsung tablet with 11ac, that gets at least 90Mbps every single time.
I’ve tried experiment with various values, single or dual chain, switching antennas, some gaining some extra Mbps, but then intruducting latency and drops. Using 2x2 is even worse (except for the TP-link that can hit >200Mbps)
Is there some known issue, critical setting or something to aviod with Apple-Broadcom products? Does only Broadcom work good with other Broadcom hardware?
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=4 band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee comment="WiFi / 5Ghz" country=sweden dfs-mode=no-radar-detect disabled=no distance=indoors frequency=5260 frequency-mode=regulatory-domain max-station-count=32 mode=ap-bridge rx-chains=0,1 security-profile=wpa_5ghz ssid=???????? wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
Running 6.33 and -cm2 package.
Does other Broadcom based hardware also have issues, or it’s a OSX-issue?
Thanks in advance
Upgraded to OSX El Capitan 10.11.2
It’s actually very good now! Getting stable 220-260Mbps now in AC/40Mhz/2S Seems like Apple has fixed some issues.
