Mikrotik 912G work with sim card Yota 4G/LTE ?
For a SIM card you need an adapter miniPCI-E ?
Какой LTE модуль подходит для Mikrotik 912G-2HnD ?
Which LTE module is suitable for Mikrotik 912G-2HnD ?
Если компания Yota использует в своих устройствах Gemtek 3GPP
If the company Yota uses in its devices Gemtek 3GPP
http://www.gemtek.com.tw/pro_LTE_WLTPEG.htm
you can check here for supported hardware. However, if you use USB device, you have to place sim card into the module, if a card with miniPCIe interface then place sim on the router.
Also note that only 1 USB device can be in use as 4G modems usually have USB electrical interface.
Это работает?
It work?
Internet centr Yota WLTFGR-102
http://www.mikrotik-shop.de/product_info.php?language=en&products_id=806
From the official list which model is right?
Where to order these modules?
4G LTE cards
http://wiki.mikrotik.com/wiki/Supported_Hardware#4G_LTE_cards
Which standard supports router?
DIRECTIP or QMI
for full speed use DIRECTIP firmware.
When will support TDD modules for Russian operator Megafon?
TDD-LTE 2600MHz(Band38)
FDD-LTE 2600MHz(Band38)
ZTE ME3760 Mini PCIe 4G LTE Wireless Module
http://www.4gltemall.com/zte-me3760-mini-pcie-4g-lte-wireless-module.html
http://www.ztedevices.com/product/Module/e70702a7-f9d5-4c72-af3c-50e92d1a6989.html
Аre silent ![]()
if you have such ZTE ME3760 modem, attach it to the board and make support output file then send it to support@mikrotik.com
We do have one.can you help to dialup correctly?
