MikroTik Access Point 802.11
Hi
Does connecting other 802.11 vendors antennas rather than mikrotik to a MikroTik Access point working on 802.11 standard effect its performance ??
Thank U
Which model do you mean?
Antennas are antennas. If the device has antenna connectors, you can use any antenna that is designed for the frequency your device is configured for (2GHz antenna for 2GHz AP)
