MikroTik Advanced User = MTCNA ?
MikroTik Advanced User certificate is the same as MikroTik certified MTCNA certificate?
Thanks =)
MTCNA is Mikrotik Certified Network Associate. This is the base Mikrotik Certificate that’s required before you undertake other Mikrotik certifications.
http://www.mikrotik.com/pdf/MTCNA_Outline.pdf
After this certification you would undertake MTCRE or MTCWE depending on your requirements.
I’m asking because I’ve found a MTCNA training/course that says you’ll get MikroTik Advanced User certificate (if you pass the online test) so I wanted to know if it is the same as MTCNA certificate :wink:
