Hi all
I was wondering if there is such a solution on the 10Ghz bands. Any hint is appreciated.
Thank you
Hi all
Thank you
Hmm, Id say no. The best bet is to use a up/down converter. Its the same principle behind the sr9.
Doubt you’ll be able to find a 2.4<–>10 GHZ convertor but its still worth searching.
Regards.
Don’t think there is any converter ready made. But depending on what you want to spend RF Linx can custom build such a device.
Erik
Hi i will have a up/down converter ready soon
from 5ghz to 10 ghz.
and i have a custom build combiner /diplexer for 4 diffrent transmitters to one antenna! this is for the 5-6 ghz band. the chanel separation is around 26-30 db. so i hope it will work.
//Rickard
Since you seem to the ability, could you do a converter from the 5gh bands to uhf channels below 746mhz? I have a good market if the price is cheap enough to use in CPE’s.
Hi Ejansson
I will look in to that, can you give me more info off topic?
to rickard (AT) rbcom.se
//Rickard
