Mikrotik and Certification Authority
Hello to all.
I have a question to ask you regarding the management of certificates.
Someone you do know how to create a “Certification Authority” DIRECTLY on mikrotik and then issue certificates and / or revocation?I tried / tried all guides possible but did not succeed.
Is this under Certificates - i.e. the SCEP related features? (You can also generate PKI key pairs in /IP IPsec under keys. but it isn’t very CA-like.)
ok, thanks.
How to Build a SCEP server? I did not succeed.
When I create it gives me the “CA Certificate: unknown”. I have created a CA with easy-rsa and I imported. but I get the same error. Should I create it on mikrotik? and if so, how?
