Mikrotik and cisco
When the ethernet of station bridge side in a p2p wireless is connected to a cisco 2960 sw, the switch interface changes to err disable. Do you know why and what is the solution?
Most likely bpdugard. Check Ciscolog for error reason.
What is the solution?
Did you look at the Cisco log what the cause was. I have an idea, and if you look at the Cisco log, you can google it and have the same idea. It is called “Pointing someone in the right direction” .
Cisco: show interface status | err
will show you why port has got that error, security issues, link flapping etc…
