Mikrotik and datacenter
I bought an RB450G. I want to use it for datacenter.
“ether1-gateway” cable wore.
“ether5-local” instead of hooked up the computer.
ip address is 91.93.61.0/24. mikrotik was “91.93.61.2”.
“91.93.61.50” manuel ip and how the computer can get it?
Thank you for help :slight_smile:
hi
how many bandwith you have in this router?
bandwidth 10m. miktrik as routers, will you? I have just swich fiber. I want to deploy real-ipx computers only.
I want to make an example;
mikrotik gateway port (input swich) = 91.93.61.0/24
mikrotik ether5 port (output computer)= 91.93.61.16/29
