mikrotik and dma rad man.
Hello!,
After a lot of tries i wanth your help on how to configure the dma to send emails with external smtp. if you can help me writing some commands and their definition e.g.
(‘smtp_relay’, ‘localhost’); here you will write your smtp server ip… (just example)
my settings are the following:
smtp ip:162.221.185.10 (is not gmail and doesn’t need tls/ssl)
port: 26
thanks
