Mikrotik and Giga ethernet Cards
I’m havin’ some issues with some Giga Ethernet Cards(intel) or i believe it is the card problem.
Every 60 seconds ( around that ) the connections drop to 0 on both Giga Cards.
Cpu is around 1% to 5%.
Mem usage aroung 10 MB…
I’m using PPPoE to the ADSL clients.
Run out of options.
Another issue… winbox also disconnect and can’t login for a while.
Any ideia what could be?
TUrn off auto negotiation ? Check the snmp OIDs to see if you are having any CRC or other errors.
Sam
Auto negociation is off.
snmp oid on ether2 GIG intel card
IF-MIB::ifInErrors.2 = Counter32: 2762
IF-MIB::ifOutErrors.2 = Counter32: 0
there are errors on ether2
ether2 is connected to internet…
ether3 is connected to ADSL clients… it’s a 100 mbits Realtec…
IF-MIB::ifInErrors.3 = Counter32: 3
IF-MIB::ifOutErrors.3 = Counter32: 0
Could it be that the cards are sharing the same IRQ ?
IRQ OWNER
1 keyboard
2 APIC
4 serial port
5 [usb-uhci]
5 [usb-uhci]
8 [rtc]
10 [usb-uhci]
10 ether1
10 ether3
10 ether2
11 [usb-uhci]
14 IDE 1
0 03:02.0 Intel Corporation 82541GI/PI Gigabit Ethernet Controller (rev: 0) 10
1 03:01.0 Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev: 16) 10
2 03:00.0 ATI Technologies Inc Rage XL (rev: 39) 5
3 02:01.0 Intel Corporation 82547GI Gigabit Ethernet Controller (rev: 0) 10
4 00:1f.3 Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller (rev: 2) 10
MT cannot recognise my gig. DLink DGE-530T Rev.B1 card , although this card is reported to be compatible. ( http://www.mikrotik.com/docs/ros/2.9/guide/driverlist )
Maybe the reason is the revision of the card.
DGE-530T Rev.A1 has Marvell 88e8003 (as i found on the internet)
DGE-530T Rev.B1 has Marvell 88e8001 (as i saw on the card)
Found here a similar problem http://contribs.org/bugzilla/show_bug.cgi?id=1634
yes, they changed to marvell sometime recently, and we don’t support that revision yet.
