I’m a noob in Mikrotik and Scripting. But i got the same error as @irghost got.
However, if I try to run the tg_cmd_hi directly from terminal, then it would run without problems (lack of $from variable, of course)
So it seems that it’s not a tg_config problem, or it won’t run in that case…
Here’s what I got from terminal running tg_getUpdates:
[edit]: I’m using ROS ver 6.40.5, if that helps
tg: Load config
trusted=2312312312;trusted=12345678
botID=42123367:OOOOOOOOOOOOOOOOOOOOOlAQ
storage=
timeout=1
Reading updates...
>> /tool fetch dst-path="tg_get_updates.txt" url="https://api.telegram.org/bot42123367:OOOOOOOOOOOOOOOOOOOOOlAQ/getUpdates?timeout=1&limit=1&offset=1151
68289"
Finished to read updates.
message id=23
update id=115168289
from id=2312312312
first name=Joshua
last name=Huang
username=jhuang
name=Joshua Huang
in chat=2312312312
command=/hi
cmd=<hi>
params=<>
Try to invoke external script tg_cmd_hi
2312312312
Joshua Huang
tg: Load config
status: failed
failure: closing connection: <400 Bad Request> 149.154.167.200:443 (5)
BlackVS
December 28, 2017, 2:55pm
22
Before last command in tg_SendMessage insert debug command:
:put $url
(or :log $url) and check URL composed by this script.
As variant - wrong botID or chatID.
After send command /health to mybot, i have tracert my error log, :
/system script run tg_getUpdates
tg: Load config
trusted=263160993
botID=504794943:AAEyJkLCZljTmb-cKumVAKa1OtdvmbsnWaU
storage=
timeout=1
Reading updates…
/tool fetch dst-path=“tg_get_updates.txt” url=“https://api.telegram.org/bot504794943:AAEyJkLCZljTmb-cKumVAKa1OtdvmbsnWaU/getUpdates?timeout=1&limit=1&offset=790797188 ”
message id=149
update id=790797188
from id=263160993
first name=Fendi
last name=Kurniawan
username=
in chat=263160993
command=/health
cmd=
params=<>
Try to invoke external script tg_cmd_health
263160993
Fendi Kurniawan
ambiguous value of value-name, more than one possible value matches input
shaider
February 7, 2018, 11:11am
24
is it possible to send command via telegram then execute in RouterBOARD?
BlackVS
February 7, 2018, 12:00pm
25
zivtal
February 13, 2018, 12:03am
27
I tried the script, Nice job. But I have got problem with updates, It’s seems like tgGetkey not working well…
I’m allways getting:
command=
cmd=<>
params=<>
When I’m opening the file I see the incoming message (“Hi” in this example)…
{“ok”:true,“result”:[{“update_id”:44584376,
“message”:{“message_id”:10,“from”:{“id”:542535389,“is_bot”:false,“first_name”:“Metal”,“last_name”:“Jef”,“username”:“mjef”,“language_code”:“en-US”},“chat”:{“id”:542535389,“first_name”:“Metal”,“last_name”:“Jef”,“username”:“mjef”,“type”:“private”},“date”:1518475137,“text”:“Hi”}}]}
Any idea why tgGetkey not working well ?
BlackVS
February 13, 2018, 6:35am
28
Command must start from /,
i.e “/hi” but not “hi”.
Also this command should be set for you bot via @BotFarther ’s /setcommands.
PS: sample commands done in lowercase, i.e “/hi”, not “/Hi”. Case makes difference too.
zivtal
February 13, 2018, 9:14am
29
Great, Thanks. I’m new with telegram …
More question how I’m sending $cmd and $params in message?
zivtal
February 13, 2018, 9:30am
30
I’m trying to make telegram available by global (enviroment), This is the complete script:
:global tgBotAPI "XXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
:global tgDefaultChatID "AAAAAAAA,BBBBBBBB,CCCCCCC";
:global tgTrusted "AAAAAAAA,BBBBBBBB,CCCCCCC";
:global tgStorage "";
:global tgTimeout 1;
:global tgSendMessage do={
:global tgBotAPI;
:global tgStorage;
:global tgDefaultChatID;
:local tgID $tgDefaultChatID
:if ([:len $chat]>0) do={ set tgID $chat }
:foreach chatID in=[:toarray $tgID] do={
:local fail false;
:local url "https://api.telegram.org/bot$tgBotAPI/sendmessage\?chat_id=$chatID&text=$text"
:if ([:len $mode]>0) do={:set url ($url."&parse_mode=$mode")}
:do {
/tool fetch url=$url keep-result=no
} on-error={
:log error "failed to send telegram message to '$chatID'."
:set fail true;
:if (!$fail) do={
:log info "telegram message has been sent to '$chatID'"
:global tgGetUpdates do={
:global tgLastMsgID
:global tgLastUPDID
:local tgGetkey do={
:local cur 0
:local lkey [:len $key]
:local res ""
:local p
:if ([:len $block]>0) do={
:set p [:find $text $block $cur]
:if ([:type $p]="nil") do={
:return $res
:set cur ($p+[:len $block]+2)
:set p [:find $text $key $cur]
:if ([:type $p]!="nil") do={
:set cur ($p+lkey+2)
:set p [:find $text "," $cur]
:if ([:pick $text $cur]="\"") do={
:set res [:pick $text ($cur+1) ($p-1)]
} else={
:set res [:pick $text $cur $p]
:return $res
:local http do={
:local res "fetchresult.txt"
:if ([:len $resfile]>0) do={:set res $resfile}
#:put $res
:local cmd "/tool fetch"
:if ([:len $mode]>0) do={:set cmd "$cmd mode=$mode"}
:if ([:len $upload]>0) do={:set cmd "$cmd upload=$upload"}
:if ([:len $user]>0) do={:set cmd "$cmd user=\"$user\""}
:if ([:len $password]>0) do={:set cmd "$cmd password=\"$password\""}
:if ([:len $address]>0) do={:set cmd "$cmd address=\"$address\""}
:if ([:len $host]>0) do={:set cmd "$cmd host=\"$host\""}
:if ([:len $"http-data"]>0) do={:set cmd "$cmd http-data=\"$"http-data"\""}
:if ([:len $"http-method"]>0) do={:set cmd "$cmd http-method=\"$"http-method"\""}
:if ([:len $"check-certificate"]>0) do={:set cmd "$cmd check-certificate=\"$"check-certificate"\""}
:if ([:len $"src-path"]>0) do={:set cmd "$cmd src-path=\"$"src-path"\""}
:if ([:len $"dst-path"]>0) do={:set cmd "$cmd dst-path=\"$"dst-path"\""}
:if ([:len $ascii]>0) do={:set cmd "$cmd ascii=\"$ascii\""}
:if ([:len $url]>0) do={:set cmd "$cmd url=\"$url\""}
:put ">> $cmd"
:global FETCHRESULT
:set FETCHRESULT "none"
:local script "\
:global FETCHRESULT;\
:do {\
$cmd;\
:set FETCHRESULT \"success\";\
} on-error={\
:set FETCHRESULT \"failed\";\
:execute script=$script file=$res
:local cnt 0
#:put "$cnt -> $FETCHRESULT"
:while ($cnt<100 and $FETCHRESULT="none") do={
:delay 1s
:set $cnt ($cnt+1)
:local content [/file get [find name=$res] content]
#:put $content
if ($content~"finished") do={:return "success"}
:return $FETCHRESULT
:global tgTrusted [:toarray $tgTrusted];
:global tgBotAPI;
:global tgStorage;
:global tgTimeout;
:put "cfg=$cfg"
:put "trusted=$tgTrusted"
:put "botID=$tgBotAPI"
:put "storage=$tgStorage"
:put "timeout=$tgTimeout"
:local file ($tgStorage."tg_get_updates.txt")
:local logfile ($tgStorage."tg_fetch_log.txt")
#get 1 message per time
:local url ("https://api.telegram.org/bot".$tgBotAPI."/getUpdates?timeout=$tgTimeout&limit=1")
:if ([:len $tgLastUPDID]>0) do={
:set url "$url&offset=$($tgLastUPDID+1)"
:put "Reading updates..."
:local res [$http dst-path=$file url=$url resfile=$logfile]
:if ($res!="success") do={
:put "Error getting updates"
:return "Failed get updates"
:put "Finished to read updates."
:local content [/file get [/file find name=$file] contents]
:local msgid [$tgGetkey key="message_id" text=$content]
:if ($msgid="") do={
:put "No new updates"
:return 0
} else={
:set tgLastMsgID $msgid
:local updid [$tgGetkey key="update_id" text=$content]
:set tgLastUPDID $updid
:local tgFromID [$tgGetkey block="from" key="id" text=$content]
:local tgUsername [$tgGetkey block="from" key="username" text=$content]
:local tgFirstName [$tgGetkey block="from" key="first_name" text=$content]
:local tgLastName [$tgGetkey block="from" key="last_name" text=$content]
:local tgID [$tgGetkey block="chat" key="id" text=$content]
:local tgMessage [$tgGetkey block="chat" key="text" text=$content]
:local tgName "$tgFirstName $tgLastName"
:put "message id=$msgid"
:put "update id=$updid"
:put "from id=$tgFromID"
:put "first name=$tgFirstName"
:put "last name=$tgLastName"
:put "username=$tgUsername"
:if ([:len $tgName]<2) do {
:if ([:len $tgUsername]>0) do={
:set tgName $tgUsername
} else={
:set tgName "Unknown"
:put "name=$tgName"
:put "in chat=$tgID"
:put "command=$tgMessage"
:local allowed ( [:type [:find $tgTrusted $tgFromID]]!="nil" or [:type [:find $tgTrusted $tgID]]!="nil")
:if (!$allowed) do={
:put "Unknown sender, keep silence"
:return -1
} else={
:local cmd ""
:local params ""
:local ltext [:len $tgMessage]
:local pos [:find $tgMessage " "]
:if ([:type $pos]="nil") do={
:set cmd [:pick $tgMessage 1 $ltext]
} else={
:set cmd [:pick $tgMessage 1 $pos]
:set params [:pick $tgMessage ($pos+1) $ltext]
:local pos [:find $cmd "@"]
:if ([:type $pos]!="nil") do={
:set cmd [:pick $cmd 0 $pos]
:put "cmd=<$cmd>"
:put "params=<$params>"
:put $tgMessage;
:global tgLastCmd $cmd
:put "Try to invoke external script tg_cmd_$cmd"
:local script [:parse [/system script get "tg_cmd_$cmd" source]]
$script params=$params chatid=$tgID from=$tgName
tgSendMessage work from mikrotik’s terminal command line, But from another script it’s not running :\ Any idea why?
From mikrotik command line I wrote (this is work) :
[$tgSendMessage chat=XXXXXXXXX text="test message"]
From another script I wrote (this is not working ) :
BlackVS
February 13, 2018, 11:07am
31
How do you call another script - from terminal manualy or , for example, via scheduler?
If from terminal you should see error messages to get issue why it happens.
PS: calling from another script are you 100% sure that needed globals exist? Due to globals live only by next reboot. It is the reason why I use “config” script.
zivtal
February 13, 2018, 3:58pm
32
Everything working… I modified your script, now it’s create scheduler every 15mins check telegram updates and if telegram’s global not exists create it…
integrated all command into one “telegram” global, commands:
Receive messages (get updates): $telegram / $telegram action=receive
Send messages: $telegram action=send chat= text= mode=
BTW- Added “if tg_cmd script not found, create temporary script running the incoming message as command”, for example: if income message is “/interface disable ether1” the script will do it. -not sure how much it’s secured, I’m still work on limitations
About the config script, you right. I’ll move back to config script. about “telegram” global it’s not problem, as I said the scheduler recreate global if not exists and check for updates.
:global tgBotAPI "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
:global tgDefaultChatID "AAAAAAAAA,BBBBBBBBB,CCCCCCCC"
:global tgTrusted "AAAAAAAAA,BBBBBBBBB,CCCCCCCC"
:global tgTimeout 1
/system scheduler add name=telegram interval=15m on-event="
:if ([:len [/system script environment find name=telegram]]=0) do={
:global telegram do={
#send message
:local tgSendMessage do={
:global tgBotAPI;
:global tgStorage;
:local tgID \$tgDefaultChatID
:if ([:len \$chat]>0) do={ set tgID \$chat }
:foreach chatID in=[:toarray \$tgID] do={
:local fail false;
:local url \"https://api.telegram.org/bot\$tgBotAPI/sendmessage\?chat_id=\$chatID&text=\$text\"
:if ([:len \$mode]>0) do={:set url (\$url.\"&parse_mode=\$mode\")}
:do {
/tool fetch url=\$url keep-result=no
} on-error={
:log error \"failed to send telegram message to '\$chatID'.\"
:set fail true;
:if (!\$fail) do={
:log info \"telegram message has been sent to '\$chatID'\"
#receive message
:local tgReceiveMessage do={
:global tgLastMsgID
:global tgLastUPDID
:local cur 0
:local lkey [:len \$key]
:local res \"\"
:local p
:if ([:len \$block]>0) do={
:set p [:find \$text \$block \$cur]
:if ([:type \$p]=\"nil\") do={
:return \$res
:set cur (\$p+[:len \$block]+2)
:set p [:find \$text \$key \$cur]
:if ([:type \$p]!=\"nil\") do={
:set cur (\$p+lkey+2)
:set p [:find \$text \",\" \$cur]
:if ([:pick \$text \$cur]=\"\\\"\") do={
:set res [:pick \$text (\$cur+1) (\$p-1)]
} else={
:set res [:pick \$text \$cur \$p]
:return \$res
:local http do={
:local res \"fetchRESULT.txt\"
:if ([:len \$resfile]>0) do={:set res \$resfile}
#:put \$res
:local cmd \"/tool fetch\"
:if ([:len \$mode]>0) do={:set cmd \"\$cmd mode=\$mode\"}
:if ([:len \$upload]>0) do={:set cmd \"\$cmd upload=\$upload\"}
:if ([:len \$user]>0) do={:set cmd \"\$cmd user=\\\"\$user\\\"\"}
:if ([:len \$password]>0) do={:set cmd \"\$cmd password=\\\"\$password\\\"\"}
:if ([:len \$address]>0) do={:set cmd \"\$cmd address=\\\"\$address\\\"\"}
:if ([:len \$host]>0) do={:set cmd \"\$cmd host=\\\"\$host\\\"\"}
:if ([:len \$\"http-data\"]>0) do={:set cmd \"\$cmd http-data=\\\"\$\"http-data\"\\\"\"}
:if ([:len \$\"http-method\"]>0) do={:set cmd \"\$cmd http-method=\\\"\$\"http-method\"\\\"\"}
:if ([:len \$\"check-certificate\"]>0) do={:set cmd \"\$cmd check-certificate=\\\"\$\"check-certificate\"\\\"\"}
:if ([:len \$\"src-path\"]>0) do={:set cmd \"\$cmd src-path=\\\"\$\"src-path\"\\\"\"}
:if ([:len \$\"dst-path\"]>0) do={:set cmd \"\$cmd dst-path=\\\"\$\"dst-path\"\\\"\"}
:if ([:len \$ascii]>0) do={:set cmd \"\$cmd ascii=\\\"\$ascii\\\"\"}
:if ([:len \$url]>0) do={:set cmd \"\$cmd url=\\\"\$url\\\"\"}
:put \">> \$cmd\"
:global fetchRESULT
:set fetchRESULT \"none\"
:local script \"\
:global fetchRESULT;\
:do {\
\$cmd;\
:set fetchRESULT \\\"success\\\";\
} on-error={\
:set fetchRESULT \\\"failed\\\";\
:execute script=\$script file=\$res
:local cnt 0
#:put \"\$cnt -> \$fetchRESULT\"
:while (\$cnt<100 and \$fetchRESULT=\"none\") do={
:delay 1s
:set \$cnt (\$cnt+1)
:local content [/file get [find name=\$res] content]
#:put \$content
if (\$content~\"finished\") do={:return \"success\"}
:return \$fetchRESULT
:global tgTrusted [:toarray \$tgTrusted];
:global tgBotAPI;
:global tgStorage;
:global tgTimeout;
:put \"cfg=\$cfg\"
:put \"trusted=\$tgTrusted\"
:put \"botID=\$tgBotAPI\"
:put \"storage=\$tgStorage\"
:put \"timeout=\$tgTimeout\"
:local file (\$tgStorage.\"tg_get_updates.txt\")
:local logfile (\$tgStorage.\"tg_fetch_log.txt\")
:local url (\"https://api.telegram.org/bot\".\$tgBotAPI.\"/getUpdates?timeout=\$tgTimeout&limit=1\")
:if ([:len \$tgLastUPDID]>0) do={
:set url \"\$url&offset=\$(\$tgLastUPDID+1)\"
:put \"Reading updates...\"
:local res [\$http dst-path=\$file url=\$url resfile=\$logfile]
:if (\$res!=\"success\") do={
:put \"Error getting updates\"
:return \"Failed get updates\"
:put \"Finished to read updates.\"
:local content [/file get [/file find name=\$file] contents]
:local msgid [\$tgGetkey key=\"message_id\" text=\$content]
:if (\$msgid=\"\") do={
:put \"No new updates\"
:return 0
} else={
:set tgLastMsgID \$msgid
:local updid [\$tgGetkey key=\"update_id\" text=\$content]
:set tgLastUPDID \$updid
:local tgFromID [\$tgGetkey block=\"from\" key=\"id\" text=\$content]
:local tgUsername [\$tgGetkey block=\"from\" key=\"username\" text=\$content]
:local tgFirstName [\$tgGetkey block=\"from\" key=\"first_name\" text=\$content]
:local tgLastName [\$tgGetkey block=\"from\" key=\"last_name\" text=\$content]
:local tgID [\$tgGetkey block=\"chat\" key=\"id\" text=\$content]
:local tgMessage [\$tgGetkey block=\"chat\" key=\"text\" text=\$content]
:local tgName \"\$tgFirstName \$tgLastName\"
:put \"message id=\$msgid\"
:put \"update id=\$updid\"
:put \"from id=\$tgFromID\"
:put \"first name=\$tgFirstName\"
:put \"last name=\$tgLastName\"
:put \"username=\$tgUsername\"
:if ([:len \$tgName]<2) do {
:if ([:len \$tgUsername]>0) do={
:set tgName \$tgUsername
} else={
:set tgName \"Unknown\"
:put \"name=\$tgName\"
:put \"in chat=\$tgID\"
:put \"command=\$tgMessage\"
:local allowed ( [:type [:find \$tgTrusted \$tgFromID]]!=\"nil\" or [:type [:find \$tgTrusted \$tgID]]!=\"nil\")
:if (!\$allowed) do={
:put \"Unknown sender, keep silence\"
:return -1
} else={
:local cmd \"\"
:local params \"\"
:local ltext [:len \$tgMessage]
:local pos [:find \$tgMessage \" \"]
:if ([:type \$pos]=\"nil\") do={
:set cmd [:pick \$tgMessage 1 \$ltext]
} else={
:set cmd [:pick \$tgMessage 1 \$pos]
:set params [:pick \$tgMessage (\$pos+1) \$ltext]
:local pos [:find \$cmd \"@\"]
:if ([:type \$pos]!=\"nil\") do={
:set cmd [:pick \$cmd 0 \$pos]
:put \"cmd=<\$cmd>\"
:put \"params=<\$params>\"
:global tgLastCmd \$cmd
:if ([:len [/system script find name=\"tgCmd_\$cmd\"]]>0) do={
:put \"Try to invoke external script tg_cmd_\$cmd\"
:local script [:parse [/system script get \"tg_cmd_\$cmd\" source]]
\$script params=\$params chatid=\$tgID from=\$tgName
} else={
:log warning \"command (\$tgMessage) has been received from '\$tgName' (\$tgID) via telegram\";
:local tgScriptFile \"tgTemp\";
:local tgScriptSource (\"
:local tgSend \\\$tgSendMessage
:do {
:local fail false;
\$tgMessage
} on-error={
:set \\\$fail true;
:if (!\\\$fail) do={
\\\$tgSend chat=\$tgID text=\\\"Command '\$tgMessage' has been done.\\\"
:log warning \\\"telegram command '\$tgMessage' received from '\$tgName' (\$tgID) has been done.\\\"
} else={
\\\$tgSend chat=\$tgID text=\\\"Error command '\$tgMessage'.\\\"
:log error \\\"telegram command '\$tgMessage' received from '\$tgName' (\$tgID) has been failed.\\\"
/system script remove [/system script find name=\\\"\$tgScriptFile\\\"]
/system script add name=\$tgScriptFile source=\$tgScriptSource;
/system script run \$tgScriptFile;
/system script environment remove [/system script environment find name=\"fetchRESULT\"];
:if (([:len \$action]=0) or (\$action=\"receive\")) do={
\$tgReceiveMessage;
} else={
:if (\$action=\"send\") do={
\$tgSendMessage chat=\$chat text=\$text;
:global telegram
\$telegram
:execute script=[/system scheduler get value-name=on-event telegram]
zivtal
February 13, 2018, 11:58pm
33
Any idea how to build string for telegram message (new line and etc,..), for example I would like to do foreach on every hotspot active connection create $str and send it by telegram message…
Attached example code that I would like to send, I’m getting failed when I’m trying to send $mailBody via telegram message…
I’m think that because I used ‘\n’ for newline… anything I can do to send it? any alternative to ‘\n’ ?
:foreach userIndex in=[/ip hotspot user find profile=generated and server=guests] do={
:local loginName [/ip hotspot user get value-name=name $userIndex];
:local loginPass [/ip hotspot user get value-name=password $userIndex];
:local loginMAC [/ip hotspot user get value-name=mac-address $userIndex];
:local loginComment [/ip hotspot user get value-name=comment $userIndex];
:if ([:len [:find [/ip hotspot user get value-name=comment $userIndex] "last connection was at"]]>0) do={
:local loginLastTime [:pick [/ip hotspot user get value-name=comment $userIndex] ([:find [/ip hotspot user get value-name=comment $userIndex] "last connection was at"]+23) ([:find [/ip hotspot user get value-name=comment $userIndex] "last connection was at"]+23+11)];
:local loginDaysAgo [$calcDays $loginLastTime [/system clock get date]];
:set loginComment [:pick [/ip hotspot user get value-name=comment $userIndex] 0 ([:find [/ip hotspot user get value-name=comment $userIndex] "last connection was at"]-2)];
:if ($loginDaysAgo>30) do={
/ip hotspot user remove $userIndex;
:log warning "The user '$loginName' was removed. The account not being use more then 30 days.";
:set loginComment "<expired>";
:set mailSend true;
:set loginComment ($loginComment."\nLast seen: $loginLastTime ($loginDaysAgo days ago)");
:if ([:len $loginMAC]>0) do={
:set mailBody ($mailBody."\nUsername: $loginName\nPassword: $loginPass\nMAC Address: $loginMAC\nComment: $loginComment\n");
} else={
:set loginMAC "<unsigned>";
:set mailBody ("\nUsername: $loginName\nPassword: $loginPass\nMAC Address: $loginMAC\nComment: $loginComment\n".$mailBody);
BlackVS
February 14, 2018, 11:01am
34
This forum needs “Like” button %) Good job!
BlackVS
February 14, 2018, 11:06am
35
Check tg_cmd_health code for multi-line.
If shortly - new line is coded as “%0A” not “\n”. It is from URL encoding rules.
Also check https://core.telegram.org/bots/api#markdown-style (markdown style) for simplified formatting in Telegram.
zivtal
February 16, 2018, 6:36am
36
doblonk
September 1, 2018, 6:08pm
37
Script is work.
When I run script from terminal I get message in Telegram.
But when I reply /hi and /health, bot not respond.
Please someone help me
Xi2
October 1, 2018, 5:57am
38
Hi!
Have tested the script and got an answer on Hi command from bot:
Hi \u0421\u0435\u0440\u0433\u0435\u0439 , how are you?
Martin4
December 30, 2018, 11:13pm
39
if i try to run script tg_cmd_xxxx separately they works fine…
when i send /message from telegram to bot, run tg_getUpdates in telnet and i receive “no such item”
tg: Load config
trusted=xxxxxxxx;trusted=yyyyyyyy
botID=zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
storage=/disk1/
timeout=1
Reading updates...
>> /tool fetch dst-path="/disk1/tg_get_updates.txt" ....................
no such item
any idea??
Thank you
Xi2
February 12, 2019, 11:52am
40
Try this:
“storage”=“flash/”;
instead of disk
