mikrotik and unifi
Hi All,
I recently got a few unifi outdoor ap’s, the AC version. Having used other ubnt stuff, i must say it’s quite different.
I’m needing to use the ap’s to run on mikrotik’s hotspot system, which i’ve managed to config through the guest control and activating both custom portal IP and hostname.
I’m having some issues with apple devices, mainly those running OSx, ios seems to be alright so far. They connect to the network but arent redirected to the login page. If i go onto the guests tab of the controller and “authorise” the connection it then connects the devices, but thats far from ideal.
Has anyone experienced this before? And if so, solution?
Thanks in advance!
Install https certificate for hotspot.
Some new toys, like iDevices have for default web page one page with https://
You must certify the https with a certificate certified by certificates certifying certifiers on HotSpot for https.
You can also search on my post all the defects those toys have, like lowercase letters on SSID…
