MikroTik and VMware
Hello all,
I am a beginner to MikroTik. I have just installed the RouterOS on VMware as a virtual machine. I also installed two XP virtual machines. The MikroTik has two ethernet interfaces, which are connected to two different HUBs. On each HUB, i connected the XP machines. Like this:
XP1 = HUB = MikroTik = HUB = XP2
On the MikroTik RouterOS i added ip addresses to the interfaces:
add address=192.168.0.0/24 interface=ether1
add address=192.168.1.0/24 interface=ether2
Then i setup a DHCP server on both interfaces:
ip dhcp-server> setup
Select interface to run DHCP server on
dhcp server interface: ether1
Select network for DHCP addresses
dhcp address space: 192.168.0.0/24
Select gateway for given network
gateway for dhcp network: 192.168.0.1
Select pool of ip addresses given out by DHCP server
addresses to give out: 192.168.0.2-192.168.0.254
Select DNS servers
dns servers: 192.168.0.1
Select lease time
lease time: 3d
[admin@MikroTik] ip dhcp-server>
and
dhcp server interface: ether2
dhcp address space: 192.168.1.0/24
gateway for dhcp network: 192.168.1.1
addresses to give out: 192.168.1.2-192.168.1.254
Select DNS servers
dns servers: 192.168.1.1
Select lease time
lease time: 3d
Now, when i power on the XP machines, and set them to obtain the ip address automatically, they obtain them from the DHCP servers:
XP1=192.168.0.2/24
XP2=192.168.1.2/24
Now i try to ping.
XP1 ping XP2 → DOESN’T WOKR!
XP1 ping 192.168.0.1 (XP1 default gateway) → WORKS!
XP2 ping XP1 → DOESN’T WOKR!
XP2 ping 192.168.1.1 (XP2 default gateway) → WORKS!
XP1 ping 192.168.1.1 (XP2 default gateway) → WORKS!
XP2 ping 192.168.0.1 (XP1 default gateway) → WORKS!
Also, when trying to ping from the MiroTik to the XP1 or XP2, it DOESN’T WORK.
Can someone please help me, i am trying to connect the two xp machines, through the MiroTik, and then try some flow control methods.
If you’re using an up to date XP build turn off your firewall on both VMs. It’s on by default and I’ve found it’s normally the source of problems like this.
Worked like a charm, many many thanks.
Just one more question. If i put one interface of the MiroTik RouterOS to Bridged mode in VMware, so that it is bridged with my real router, that has a conenction to internet, and if i put thet interface of MiroTik to DHCP Client, will i be able to to the internet from my virtual XP’s, or do i have to configure something more???
Thanks in advanced.
