Mikrotik and voip
hi guyz, am using rb 1100, i have clients connected to voip gateways, i need to limit them from using more than 8 ports, since some of them use 16 ports, i have given them public i.p’s, is there a way i could do this?
This is a really, really wrong section for this. The dude is network monitering.
I assume you mean you want to limit the IP’s you have assigned to those voip GW’s to a range of 8 tcp/udp ports only?
If you have them behind a nat, half your job is done already since it will not cross the nat without having some dst or src nat rules. all you gotta do is make your NAT rules to allow those ports to access your voip GW’s.
Anywho, be more specific, which ports do you want them to have access to… and repost this in the right section.
