Mikrotik Android APP User Permisions
Hi every one, I would like to know if there is a way to modify the categories a user is able to see in the android app, like the skins in the web app. I cant fin information about it on the web, exactly what i need to do is a user with only parental management and wifi password change permisions on the android app. I will thank all the info you can give.
No i don’t think you can. That’s on webfig only.
thanks for your help, the app will be really helpful if ths configuration could be made, especially related to parental control, not all the users should have acces to all the configurations.
Create a user in winbox and give that user the permissions you want…
Then use that user in the app…
