Mikrotik API
Hi guys,
FREE-Webserver support´s Mikrotik-API:
http://ma.nasanet.de/rb
Info about API:
http://ma.nasanet.de/rb/info.php
Scripts Download for Free! To use on local Webserver.
alex
Very nice job, NasaNeuNet! I recommend everyone to look at this. A good example of API use
Any chance you could make the files available without registration please?
If you register so you can see the file and api in real work.
This version is the first one.
But i work on more options so its in your intress to give me a email adress where i can send news for new versions of this api or bug-fixes.
If I want updates, I’ll register. But for now, I’d much rather just inspect the current state, maybe report back some bugs in said current version if I find any…
Besides, you may want to consider places like GitHub or SourceForge, where users could be subsribed to updates via the site, and be notified on every change along the way. I for one probably would. If it’s on GitHub, I might even send some pull requests your way.
New options:
*- Visualization of the Interfaces
*- Bug-Fix => List Routerboards
http://ma.nasanet.de/rb/info.php#visuInterface
Change Files witch have to fix:
/api.php
/style.php
/images/*
/js/ajax/addRB.php
For more infos => info@nasaneunet.de
Good Luck! :slight_smile:
Alex
Nice work.
Sent from my SCH-I545 using Tapatalk 4
