Mikrotik API
Hi everyone,
i wanna run this mikrotik script
" :foreach i in=[/tool user-manager session find ] do {/tool user-manager session remove $i;} " into c# with api
i got this error
[0]: “!trap=category=0=message=no such command or directory (foreach i in=[)”
[1]: “!trap=message=no such command prefix”
[2]: “!done”
please check RouterOS API manual. You will see that you cannot run scripts via API.
FWIW, this is a bad way to remove all sessions, even in scripting alone.
Using “find” inside the remove itself is far more compact, as well as more efficient:
/tool user-manager session remove [find]
The only time using :foreach is necessary is if your criteria can’t be covered by the “where” inside the “find”.
To do the above (not using :foreach) using the API, you need to execute the inner command, and pass it’s results to the outer command.
So f.e.
/tool/user-manager/session/find
!done
=ret=*1,*2,*3
/tool/user-manager/session/remove
=numbers=*1,*2,*3
!done
