Mikrotik as a SSH server
Is it posible to use Mikrotik as a SSH server ?
It has ssh support if this is what you mean.
Sent from Tapatalk
I want to connect MikroTik using SSH and manage another device with SSH. It is possible via WINBOX → tool-telnet–>SSH, but not avaible via console…
why not try instead:
/system ssh
:smiley:
thank you so much :slight_smile:
As said it’s possible, but ssh impl of ROS is quite limited. You could also consider portforwarding traffic to the target system. (And for safety enable key based login.)
