Mikrotik as a WAN Emulator
is it possible to limit a user not only with the bandwith but also with a given latency or defined packet loss ?
if yes than how ? thank you very much for the help.
Greetings
You can do it with dummynet on a freebsd box. I don’t recall seeing anything in RouterOS which can provide the latency feature.
http://info.iet.unipi.it/~luigi/dummynet/
there is no normal way on how to alter latency in RouterOS beyond actual time that is required for packet processing.
