Mikrotik as a wireguard VPN client how to
After a lot of wrangling and help from anav I have come up with this simplified wireguard Mikrotik config specifically for a “VPN provider” scenario, NOT road warrior, and NOT site to site. I am going to call it “Cosmic Mikrotik Wireguard” so it will be easy to find with an internet search engine. NOTE: This is recommended to be done on a router with a fresh reset configuration.
/interface wireguard
add name="wireguard-VPN" mtu=1420 listen-port=51820 \
private-key="INSERT YOUR PRIVATE KEY HERE"
add address=YOUR.INTERFACE.ADDRESS/24 interface=wireguard-VPN network=YOUR.INTERFACE.NETWORK
#EXAMPLE: If your interface is 192.168.1.1 then your interface network would be 192.168.1.0
/interface wireguard peers
add allowed-address=0.0.0.0/0 client-dns=YOUR.VPN.DNS.SERVER \
disabled=no endpoint-address=YOUR.ENDPOINT.ADDRESS endpoint-port=YOUR ENDPOINT PORT interface=\
wireguard-VPN name=wireguard-VPN-interface persistent-keepalive=25s \
public-key=\
"INSERT YOUR PUBLIC KEY HERE"
/ipv6 settings set disable-ipv6=yes
/ipv6 firewall filter
add chain=input action=drop
add chain=forward action=drop
/ip dhcp-server network remove 0
add address=YOUR.LAN.SUBNET/24 dns-server=YOUR.VPN.DNS.SERVER gateway=YOUR.LAN.GATEWAY
/ip dns static remove 0
set allow-remote-requests=no servers=YOUR.VPN.DNS.SERVER
/routing table
add disabled=no fib name=wireguard-VPN-table
add disabled=no dst-address=0.0.0.0/0 gateway=wireguard-VPN-interface \
routing-table=wireguard-VPN-table suppress-hw-offload=no
/routing rule
add action=lookup-only-in-table dst-address=YOUR.LAN.SUBNET/24 table=main
add action=lookup-only-in-table src-address=YOUR.LAN.SUBNET/24 table=wireguard-VPN-table
/ip firewall nat remove 0
add action=masquerade chain=srcnat out-interface=wireguard-VPN-interface \
search keywords: “Cosmic Mikrotik Wireguard”
I would make some changes… as follows ( we gave used a wireguard interface name ( can use whatever you prefer) of wireguard-VPN )
THIRD PARTY VPN - one flat subnet only
add name=wireguard-VPN mtu=1420 listen-port=AnyPort#
private-key=“INSERT THE PROVIDED PRIVATE KEY HERE”
add allowed-address=0.0.0.0/0 endpoint-address=YOUR.ENDPOINT.ADDRESS endpoint-port=YOUR ENDPOINT PORT interface=
wireguard-VPN name=“Name of 3r party provider & location” persistent-keepalive=25s
public-key=“INSERT YOUR PUBLIC KEY HERE”
/ip dhcp-server network remove 0 < ---- Remove this line not sure why its here???
/ip dns static remove 0 < ---- Remove this line not sure why its here???
set allow-remote-requests=no servers=1.1.1.1,8.8.8.8
{ add if ISP default dns is not used, to ensure router has ability to reach external DNS for handshake }
add dst-address=0.0.0.0/0 gateway=ISP-gateway-IP routing-table=main
{ add if ISP default route is not selected }
add dst-address=0.0.0.0/0 gateway=wireguard-VPN-interface routing-table=wireguard-VPN-table
/ip firewall nat remove 0 < ---- Remove this line not sure why its here???
add action=masquerade chain=srcnat out-interface=etherX ( or pppoe-out1 etc.)
{ router requires a route to establish handshake }
add action=masquerade chain=srcnat out-interface=wireguard-VPN-interface { source address is not required, not a firewall or routing function }
Note: If having trouble with remote websites, then consider adding
/ip firewall mangle
add action=change-mss chain=forward new-mss=1380 out-interface=wireguard-VPN protocol=tcp tcp-flags=syn tcp-mss=1381-65535
Anav, I think some people will still use the web interface as opposed to using Winbox, so I included those remove commands in order to clear out those config items in that scenario where they may have made initial ip configurations.
Ahhh okay, my bad. Ensure though you reference that so its clear to the majority of newbies which dont use webconfig.!~
