Hi all,
I have successfully got mine working as well.
The metarouter image I used is: http://openwrt.wk.cz/attitude_adjustment/mr-mips/openwrt-mr-mips-rootfs.tar.gz
Configure your network interface by using “uci”
- Show network configutations: “uci show network”
- Show all configurations: “uci show”
[*]Set configuration: “uci set network.wan=interface”
Mine looks as follow:
network.wan.proto=static
network.wan.ipaddr=172.16.2.6
network.wan.netmask=255.255.255.252
network.wan.ifname=eth0
network.wan.gateway=172.16.2.5
network.wan.dns=172.16.2.5
network.lan=interface
network.lan.proto=static
network.lan.ipaddr=172.16.2.2
network.lan.netmask=255.255.255.252
network.lan.ifname=eth1
Where my WAN interface are used to get internet to the image and the lan will be used to access the VPN connection.
After configuring the network settings you need to commit them and restart the network service.
Run the following commands:
- uci commit network
- /etc/init.d/network restart
For some reason the dns nameserver does not take affect and you need to modify it manually at /etc/resolve.conf and enter your dns server details, otherwise you will not be able to update and download the packages needed.
Then you can install vpnc by following the tutorial here: http://wiki.openwrt.org/vpnc.vpn
- In the file created /etc/init.d/vpnc file. remove the spaces in the first few lines between the START=75 and STOP=01. It does not work with the spaces. Unable to find start/stop on line 2 and line 3 error.
- At the steps when you try to run “/etc/init.d/vpnc enable” you get an error, first enable the file to be executable by running “chmod +x /etc/init.d/vpnc” and then you will be able to enable the automatic boot script.
- IP Tables - This one I have not figured out yet. When the metarouter restarts the IPtables are missing and you need to reapply them.
You connect the VPN by either running the startup script or the vpnc client itself.
vpnc
or
/etc/init.d/vpnc start
You can then see that the tunnel is up by using ifconfig
root@metarouter:/# ifconfig
eth0 Link encap:Ethernet HWaddr 02:0B:3E:55:A6:23
inet addr:172.16.2.6 Bcast:172.16.2.7 Mask:255.255.255.252
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2517 errors:0 dropped:0 overruns:0 frame:0
TX packets:2039 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:888004 (867.1 KiB) TX bytes:364073 (355.5 KiB)
eth1 Link encap:Ethernet HWaddr 02:5B:39:4F:B5:12
inet addr:172.16.2.2 Bcast:172.16.2.3 Mask:255.255.255.252
RX packets:4787 errors:0 dropped:0 overruns:0 frame:0
TX packets:2992 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:447771 (437.2 KiB) TX bytes:679876 (663.9 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:2748 errors:0 dropped:0 overruns:0 frame:0
TX packets:2748 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:186756 (182.3 KiB) TX bytes:186756 (182.3 KiB)
tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.102.253.87 P-t-P:10.102.253.87 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1412 Metric:1
RX packets:41 errors:0 dropped:0 overruns:0 frame:0
TX packets:432 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:500
RX bytes:4428 (4.3 KiB) TX bytes:31605 (30.8 KiB)
On your route make sure that you route the ip ranges you need and masquerade it as required.
Traceroute from PC going to my gateway ( mikrotik) over to metarouter into the VPN.
C:\Users\Administrator>tracert -d 10.117.12.117
Tracing route to 10.117.12.117 over a maximum of 30 hops
1 <1 ms <1 ms 1 ms 10.20.0.254
2 2 ms 1 ms 1 ms 172.16.2.2
3 142 ms 36 ms 26 ms 10.102.250.2
4 213 ms 43 ms 37 ms 10.101.255.73
5 137 ms 24 ms 23 ms 10.101.255.206
6 114 ms 27 ms 26 ms 10.103.82.5
7 70 ms 201 ms 215 ms 10.251.201.0
Success.
Thank you for the tip of using metarouter and vpnc!
