mikrotik with ether1 and ppp-out1 interface (LAN card 100TX and USB OPTION connected to internet) but there is no routing between those 2 interface???
(from ppp interface I can ping public ip, but no from private interface)
NAME TYPE MTU L2MTU
0 R ether1 ether 1500
1 R ppp-out1 ppp-out 1500
[admin@MikroTik] /interface>
[admin@MikroTik] /ip route> print
Yes. Dont put your priovate address sapce onto a povider. Any provider with a gfrain of brain will throw packeets away that are from wrong ip addresses for a gateway.
In your case this means the 192.168.0.0 network should NOT NEVER EVER be seen by the ppp-out1 recipient. He will throw it away.
To avoid this, put in a NAT rule, so he sees the packets as originating from 10.112.112.142 (which is the ip address he assigned to your ppp-out1 interface). He will happily forward them then.
