My bad. I fixed my comment to reflect exactally your tutorial.
I was able to input my username and password, and the only Hash Algorithm that won’t lead to a FATAL is sha1 (tested one by one).
I will attach the log when using sha1 as the hash algorithm:
[admin@MikroTik] >
09:07:51 echo: ipsec,debug 0.0.0.0[500] used as isakmp port (fd=11)
09:07:51 echo: ipsec,debug 0.0.0.0[4500] used as isakmp port with NAT-T (fd=13)
09:07:51 echo: ipsec,debug ::[500] used as isakmp port (fd=14)
09:07:51 echo: ipsec,debug ::[4500] used as isakmp port (fd=15)
[admin@MikroTik] >
09:07:53 echo: ipsec,debug ===
09:07:53 echo: ipsec,info initiate new phase 1 (Aggressive): 192.168.0.20[500]<=>VPNSERVER.IP[500]
09:07:53 echo: ipsec,debug new cookie:
09:07:53 echo: ipsec,debug a937d779fc659c64
09:07:53 echo: ipsec,debug use ID type of KEY_ID
09:07:53 echo: ipsec,debug dh(modp1024)
[admin@MikroTik] >
(79 messages discarded)
09:07:53 echo: ipsec,debug seen nptype=8(hash) len=24
09:07:53 echo: ipsec,debug seen nptype=13(vid) len=20
09:07:53 echo: ipsec,debug seen nptype=13(vid) len=12
09:07:53 echo: ipsec,debug seen nptype=20(nat-d) len=24
09:07:53 echo: ipsec,debug seen nptype=13(vid) len=24
09:07:53 echo: ipsec,debug succeed.
09:07:53 echo: ipsec received Vendor ID: CISCO-UNITY
09:07:53 echo: ipsec,debug,packet f5642d6f 49d4253a 8b1e137e 70d665c4 4e2fc3ef beb819b4 70e98aa2 ce6fee90
[admin@MikroTik] >
09:07:54 echo: ipsec,debug ===== received 444 bytes from VPNSERVER.IP[500] to 192.168.0.20[500]
09:07:54 echo: ipsec,debug,packet d7029df2 8edebf2f 49298e04 1ad26851 01100400 00000000 000001bc 0400003c
09:07:54 echo: ipsec,debug,packet 00000001 00000001 00000030 01010001 00000028 01010000 80010007 800e0100
09:07:54 echo: ipsec,debug,packet 80020002 80040002 8003fde9 800b0001 000c0004 00015180 0a000084 d6c15398
09:07:54 echo: ipsec,debug,packet 1635eb63 8a5cc54a 0170b95a aa2f7f4c 7a6a8f91 414016ae 115ec823 c39662ac
09:07:54 echo: ipsec,debug,packet b97d85fa 86444c02 977ad425 1194a7b5 f66e4314 844dbe1c 6ebafba0 705a0814
09:07:54 echo: ipsec,debug,packet 5ad4b7e1 94148e21 364434a2 8b032d3e 001a9b6a 495a74ae d2be4570 4c0fcad6
09:07:54 echo: ipsec,debug,packet 33c14f71 d70e20b6 82b46a2b 38b4331e 103d10ce 8f3f7cef 8010c087 05000018
09:07:54 echo: ipsec,debug,packet 5b9a6ee8 8a154677 f9b14eb8 18c7d5eb 6514d1c6 0800000c 01110000 c81101f4
[admin@MikroTik] >
09:08:00 echo: ipsec,debug KA: 192.168.0.20[4500]->VPNSERVER.IP[4500]
09:08:00 echo: ipsec,debug 1 times of 1 bytes message will be sent to VPNSERVER.IP[4500]
09:08:00 echo: ipsec,debug,packet ff
[admin@MikroTik] >
(55 messages discarded)
09:08:01 echo: ipsec,debug type=Group Description, flag=0x8000, lorv=1024-bit MODP group
09:08:01 echo: ipsec,debug dh(modp1024)
09:08:01 echo: ipsec,debug type=Authentication Method, flag=0x8000, lorv=XAuth pskey client
09:08:01 echo: ipsec,debug type=Life Type, flag=0x8000, lorv=seconds
09:08:01 echo: ipsec,debug type=Life Duration, flag=0x0000, lorv=4
09:08:01 echo: ipsec,debug pair 1:
09:08:01 echo: ipsec,debug 0x49bf00: next=0 tnext=0
09:08:01 echo: ipsec,debug proposal #1: 1 transform
09:08:01 echo: ipsec,debug -checking with XAuth pskey client auth-
09:08:01 echo: ipsec,debug prop#=1, prot-id=ISAKMP, spi-size=0, #trns=1
09:08:01 echo: ipsec,debug trns#=1, trns-id=IKE
09:08:01 echo: ipsec,debug,packet compute DH's shared.
[admin@MikroTik] >
09:08:02 echo: ipsec,debug ===== received 444 bytes from VPNSERVER.IP[500] to 192.168.0.20[500]
09:08:02 echo: ipsec,debug,packet d7029df2 8edebf2f 49298e04 1ad26851 01100400 00000000 000001bc 0400003c
09:08:02 echo: ipsec,debug,packet 00000001 00000001 00000030 01010001 00000028 01010000 80010007 800e0100
09:08:02 echo: ipsec,debug,packet 80020002 80040002 8003fde9 800b0001 000c0004 00015180 0a000084 d6c15398
09:08:02 echo: ipsec,debug,packet 1635eb63 8a5cc54a 0170b95a aa2f7f4c 7a6a8f91 414016ae 115ec823 c39662ac
09:08:02 echo: ipsec,debug,packet b97d85fa 86444c02 977ad425 1194a7b5 f66e4314 844dbe1c 6ebafba0 705a0814
09:08:02 echo: ipsec,debug,packet 5ad4b7e1 94148e21 364434a2 8b032d3e 001a9b6a 495a74ae d2be4570 4c0fcad6
09:08:02 echo: ipsec,debug,packet 33c14f71 d70e20b6 82b46a2b 38b4331e 103d10ce 8f3f7cef 8010c087 05000018
09:08:02 echo: ipsec,debug,packet 5b9a6ee8 8a154677 f9b14eb8 18c7d5eb 6514d1c6 0800000c 01110000 c81101f4
09:08:02 echo: ipsec,debug,packet 0d000018 e35dd478 d3447bc5 5186faad 3db3c1aa 3028faeb 0d000014 12f5f28c
[admin@MikroTik] >
09:08:03 echo: ipsec,debug 850 bytes from 192.168.0.20[4500] to VPNSERVER.IP[4500]
09:08:03 echo: ipsec,debug 1 times of 854 bytes message will be sent to VPNSERVER.IP[4500]
09:08:03 echo: ipsec,debug,packet a937d779 fc659c64 00000000 00000000 01100400 00000000 00000352 04000174
09:08:03 echo: ipsec,debug,packet 00000001 00000001 00000168 01010009 03000028 01010000 800b0001 000c0004
09:08:03 echo: ipsec,debug,packet 00015180 80010007 800e0100 8003fde9 80020002 80040002 03000028 02010000
09:08:03 echo: ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0100 8003fde9 80020002 80040002
09:08:03 echo: ipsec,debug,packet 03000028 03010000 800b0001 000c0004 00015180 80010007 800e00c0 8003fde9
09:08:03 echo: ipsec,debug,packet 80020002 80040002 03000028 04010000 800b0001 000c0004 00015180 80010008
09:08:03 echo: ipsec,debug,packet 800e00c0 8003fde9 80020002 80040002 03000028 05010000 800b0001 000c0004
09:08:03 echo: ipsec,debug hashtype = SHA:SHA
09:08:03 echo: ipsec,debug,packet hmac(hmac_sha1)
[admin@MikroTik] >
(47 messages discarded)
09:08:09 echo: ipsec,debug succeed.
09:08:09 echo: ipsec,debug transform #1 len=40
09:08:09 echo: ipsec,debug type=Encryption Algorithm, flag=0x8000, lorv=AES-CBC
09:08:09 echo: ipsec,debug,packet encryption(aes)
09:08:09 echo: ipsec,debug type=Key Length, flag=0x8000, lorv=256
09:08:09 echo: ipsec,debug type=Hash Algorithm, flag=0x8000, lorv=SHA
09:08:09 echo: ipsec,debug hash(sha1)
09:08:09 echo: ipsec,debug type=Group Description, flag=0x8000, lorv=1024-bit MODP group
09:08:09 echo: ipsec,debug dh(modp1024)
09:08:09 echo: ipsec,debug type=Authentication Method, flag=0x8000, lorv=XAuth pskey client
09:08:09 echo: ipsec,debug type=Life Type, flag=0x8000, lorv=seconds
09:08:09 echo: ipsec,debug,packet compute DH's shared.
[admin@MikroTik] >
09:08:10 echo: ipsec,debug ===== received 92 bytes from VPNSERVER.IP[500] to 192.168.0.20[500]
09:08:10 echo: ipsec,debug,packet d7029df2 8edebf2f 49298e04 1ad26851 08100501 4c94847c 0000005c 04844c6c
09:08:10 echo: ipsec,debug,packet 63fa8a13 5da13e02 ed3713c0 8d377a25 ebd77b0f 448b8053 0c58d008 c293b5e4
09:08:10 echo: ipsec,debug,packet 97b8e51b 70922313 a78b2fac d3712955 d33cbdd0 05088eeb 6f025a53
09:08:10 echo: ipsec VPNSERVER.IP unknown Informational exchange received.
[admin@MikroTik] >
(4 messages discarded)
09:08:11 echo: ipsec,debug,packet 26de847d 5b301e93 e5d7d093 386e7bed 308b32cb 9dd54dc0 4391de16 806d5c5b
09:08:11 echo: ipsec,debug,packet a4b303e0 44f0644f ac4df305 ac5a9d43 afa98111 4ed02092 da14b44a ae6b3d69
09:08:11 echo: ipsec,debug,packet 6052f053 b82177c0 14bd8b76 df380317 7c949b6b b07d4188 f46f7409 66d20c96
09:08:11 echo: ipsec,debug,packet 7bb91de3 9ab03556 0b5cd012 4dd03841 b139f19d f03ec068 0bda2a3a 05000018
09:08:11 echo: ipsec,debug,packet 4dcc2f88 7917c7be 15affb38 09743db0 22af7ac6 0800000c 01110000 c81101f4
09:08:11 echo: ipsec,debug,packet 0d000018 f4fe8aab 06bb3700 55a7afbd 0f008fc5 02de2d3e 0d000014 12f5f28c
09:08:11 echo: ipsec,debug,packet 457168a9 702d9fe2 74cc0100 0d00000c 09002689 dfd6b712 0d000014 afcad713
09:08:11 echo: ipsec,debug,packet 68a1f1c9 6b8696fc 77570100 14000014 4a131c81 07035845 5c5728f2 0e95452f
09:08:11 echo: ipsec,debug,packet 14000018 c2c110d8 d8e92a38 95be47b5 ea249619 bba6b300 0d000018 631841e0
09:08:11 echo: ipsec,debug,packet a3c1864d 44d55b12 d142db4b b78fcd37 0d000018 4048b7d5 6ebce885 25e7de7f
09:08:11 echo: ipsec,debug,packet compute DH's shared.
09:08:11 echo: ipsec,debug,packet bcdecfb2 dfcde4ee 2e783688 dbfa11fd a4b9bc83 637bf6ba 2d0ecc09 03830cb3
[admin@MikroTik] >
(7 messages discarded)
09:08:13 echo: ipsec,debug,packet 80020002 80040002 03000028 04010000 800b0001 000c0004 00015180 80010008
09:08:13 echo: ipsec,debug,packet 800e00c0 8003fde9 80020002 80040002 03000028 05010000 800b0001 000c0004
09:08:13 echo: ipsec,debug,packet 00015180 80010007 800e0080 8003fde9 80020002 80040002 03000028 06010000
09:08:13 echo: ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0080 8003fde9 80020002 80040002
09:08:13 echo: ipsec,debug,packet 03000024 07010000 800b0001 000c0004 00015180 80010005 8003fde9 80020002
09:08:13 echo: ipsec,debug,packet 80040002 03000028 08010000 800b0001 000c0004 00015180 80010003 800e0080
09:08:13 echo: ipsec,debug,packet 8003fde9 80020002 80040002 00000024 09010000 800b0001 000c0004 00015180
09:08:13 echo: ipsec,debug,packet 80010001 8003fde9 80020002 80040002 0a000084 be870ea5 cd5be2b5 51f04cd1
09:08:13 echo: ipsec,debug,packet b61ea739 d53d6391 3ad36976 49befc36 af1cbe3c 23773db8 c8dac539 0e10c7f0
09:08:13 echo: ipsec,debug,packet a5c53c7b 61e86571 1f3dcc75 cce1af84 da0a5319 757ffafc c2062a74 ef9f0799
09:08:13 echo: ipsec,debug,packet 69719ffb 540ac5e1 54fa38c1 ba5e0293 ee5b1fce bcdecfb2 dfcde4ee 2e783688
09:08:13 echo: ipsec,debug,packet 000c0900 2689dfd6 b7120d00 001412f5 f28c4571 68a9702d 9fe274cc 01000000
[admin@MikroTik] >
(28 messages discarded)
09:08:17 echo: ipsec,debug seen nptype=13(vid) len=20
09:08:17 echo: ipsec,debug succeed.
09:08:17 echo: ipsec received Vendor ID: CISCO-UNITY
09:08:17 echo: ipsec received Vendor ID: draft-ietf-ipsra-isakmp-xauth-06.txt
09:08:17 echo: ipsec received Vendor ID: DPD
09:08:17 echo: ipsec,debug remote supports DPD
09:08:17 echo: ipsec received Vendor ID: RFC 3947
09:08:17 echo: ipsec received Vendor ID: FRAGMENTATION
09:08:17 echo: ipsec,debug received unknown Vendor ID
09:08:17 echo: ipsec,debug 1f07f70e aa6514d3 b0fa9654 2a500100
09:08:17 echo: ipsec,debug total SA len=56
09:08:17 echo: ipsec,debug,packet compute DH's shared.
[admin@MikroTik] >
(8 messages discarded)
09:08:19 echo: ipsec,debug,packet 4dcc2f88 7917c7be 15affb38 09743db0 22af7ac6 0800000c 01110000 c81101f4
09:08:19 echo: ipsec,debug,packet 0d000018 f4fe8aab 06bb3700 55a7afbd 0f008fc5 02de2d3e 0d000014 12f5f28c
09:08:19 echo: ipsec,debug,packet 457168a9 702d9fe2 74cc0100 0d00000c 09002689 dfd6b712 0d000014 afcad713
09:08:19 echo: ipsec,debug,packet 68a1f1c9 6b8696fc 77570100 14000014 4a131c81 07035845 5c5728f2 0e95452f
09:08:19 echo: ipsec,debug,packet 14000018 c2c110d8 d8e92a38 95be47b5 ea249619 bba6b300 0d000018 631841e0
09:08:19 echo: ipsec,debug,packet a3c1864d 44d55b12 d142db4b b78fcd37 0d000018 4048b7d5 6ebce885 25e7de7f
09:08:19 echo: ipsec,debug,packet 00d6c2d3 c0000000 00000014 1f07f70e aa6514d3 b0fa9654 2a500100
09:08:19 echo: ipsec,debug begin.
09:08:19 echo: ipsec,debug seen nptype=1(sa) len=60
09:08:19 echo: ipsec,debug seen nptype=4(ke) len=132
09:08:19 echo: ipsec,debug seen nptype=10(nonce) len=24
09:08:19 echo: ipsec,debug,packet compute DH's shared.
[admin@MikroTik] >
09:08:19 echo: ipsec,debug,packet 80020002 80040002 03000028 02010000 800b0001 000c0004 00015180 80010008
[admin@MikroTik] >
09:08:20 echo: ipsec,debug KA: 192.168.0.20[4500]->VPNSERVER.IP[4500]
09:08:20 echo: ipsec,debug 1 times of 1 bytes message will be sent to VPNSERVER.IP[4500]
09:08:20 echo: ipsec,debug,packet ff
[admin@MikroTik] >
(18 messages discarded)
09:08:23 echo: ipsec,debug,packet dbfa11fd a4b9bc83 637bf6ba 2d0ecc09 03830cb3 0500001c f1b833af f24c64f0
09:08:23 echo: ipsec,debug,packet 0158c401 22c3d792 e03391a2 24cd1d95 0d000012 0b000000 74656c65 6d617469
09:08:23 echo: ipsec,debug,packet 63610d00 00144a13 1c810703 58455c57 28f20e95 452f0d00 00148f8d 83826d24
09:08:23 echo: ipsec,debug,packet 6b6fc7a8 a6a428c1 1de80d00 0014439b 59f8ba67 6c4c7737 ae22eab8 f5820d00
09:08:23 echo: ipsec,debug,packet 00144d1e 0e136dea fa34c4f3 ea9f02ec 72850d00 001480d0 bb3def54 565ee846
09:08:23 echo: ipsec,debug,packet 45d4c85c e3ee0d00 00149909 b64eed93 7c6573de 52ace952 fa6b0d00 00147d94
09:08:23 echo: ipsec,debug,packet 19a65310 ca6f2c17 9d921552 9d560d00 0014cd60 464335df 21f87cfd b2fc68b6
09:08:23 echo: ipsec,debug,packet a4480d00 001490cb 80913ebb 696e0863 81b5ec42 7b1f0d00 001416f6 ca16e4a4
09:08:23 echo: ipsec,debug,packet 066d8382 1a0f0aea a8620d00 00144485 152d18b6 bbcd0be8 a8469579 ddcc0d00
09:08:23 echo: ipsec,debug,packet 000c0900 2689dfd6 b7120d00 001412f5 f28c4571 68a9702d 9fe274cc 01000000
09:08:23 echo: ipsec,debug,packet 0014afca d71368a1 f1c96b86 96fc7757 0100
09:08:23 echo: ipsec resent phase1 packet 192.168.0.20[4500]<=>VPNSERVER.IP[4500] a937d779fc659c64:7ef459457352800e
[admin@MikroTik] >
(12 messages discarded)
09:08:25 echo: ipsec,debug,packet 1ca72288 70435125 fd56c0f6 4b2e89c2
09:08:25 echo: ipsec,debug,packet encryption(aes)
09:08:25 echo: ipsec,debug,packet IV was saved for next processing:
09:08:25 echo: ipsec,debug,packet f4eedec5 f6da55fc c44f9c01 f03efb14
09:08:25 echo: ipsec,debug,packet with key:
09:08:25 echo: ipsec,debug,packet a6b95b70 4b87636f 861d94b8 c64dd90a 138d7657 7fab7bb8 b50529e4 037dbb31
09:08:25 echo: ipsec,debug,packet decrypted payload by IV:
09:08:25 echo: ipsec,debug,packet decrypted payload, but not trimed.
09:08:25 echo: ipsec,debug,packet d887c687 30928ce1 e2113ad1 755dcac4 486809b7 485b19d0 040dfb8d ce38a55e
09:08:25 echo: ipsec,debug,packet 8ac7211f f516395a 12459987 73ba5b2c 87e1d39c 1f74d3d4 fd9bca0a 8997d6a6
[admin@MikroTik] >
(11 messages discarded)
09:08:27 echo: ipsec,debug,packet 68a1f1c9 6b8696fc 77570100 14000014 4a131c81 07035845 5c5728f2 0e95452f
09:08:27 echo: ipsec,debug,packet 14000018 c2c110d8 d8e92a38 95be47b5 ea249619 bba6b300 0d000018 631841e0
09:08:27 echo: ipsec,debug,packet a3c1864d 44d55b12 d142db4b b78fcd37 0d000018 4048b7d5 6ebce885 25e7de7f
09:08:27 echo: ipsec,debug,packet 00d6c2d3 c0000000 00000014 1f07f70e aa6514d3 b0fa9654 2a500100
09:08:27 echo: ipsec,debug begin.
09:08:27 echo: ipsec,debug seen nptype=1(sa) len=60
09:08:27 echo: ipsec,debug seen nptype=4(ke) len=132
09:08:27 echo: ipsec,debug seen nptype=10(nonce) len=24
09:08:27 echo: ipsec,debug seen nptype=5(id) len=12
09:08:27 echo: ipsec,debug seen nptype=8(hash) len=24
09:08:27 echo: ipsec,debug,packet compute DH's shared.
09:08:27 echo: ipsec,debug,packet 00015180 80010005 8003fde9 80020002 80040002 03000028 08010000 800b0001
[admin@MikroTik] >
09:08:31 echo: ipsec,debug Removing PH1...
09:08:31 echo: ipsec,info ISAKMP-SA deleted 192.168.0.20[4500]-VPNSERVER.IP[4500] spi:a937d779fc659c64:7ef459457352800e rekey:1
09:08:31 echo: ipsec KA remove: 192.168.0.20[4500]->VPNSERVER.IP[4500]
09:08:31 echo: ipsec,debug KA tree dump: 192.168.0.20[4500]->VPNSERVER.IP[4500] (in_use=1)
09:08:31 echo: ipsec,debug KA removing this one...
